Quote Originally Posted by liftlid View Post
It's not the resolution it's when you use them zoomed in on the gps, they also don't have as much detail as a rooftop or meridian map
OK - When you scan them you can select the resolution you want them scanned at. Because they are a bit map file, the higher the resolution the smaller the dots that make up the bit map. My files are scanned at high res so my dots are so small I can zoom in a long way before I see pixels. I hope that explains it better.
