Page 319 of 1057 FirstFirst ... 317318319320321 ... LastLast
Results 3,181 to 3,190 of 10565
  1. #3181
    Replaced tapper cover gasket,fix a couple of electrical issues(fixed rpm sensor wire but cannot get temp gauge to work.....karput)fixed leg on awning...car dash still in pieces but need to order a part....
    I should add that good old rusty helped aswell...good job having a T/A
  2. The Following 2 Users Say Thank You to Avo For This Useful Post:
    BigRAWesty (19th January 2014), Rustyboner81 (19th January 2014)
  3. #3182
    Patrol Freak Rustyboner81's Avatar
    Perth
    Quote Originally Posted by wa 489 View Post
    Replaced tapper cover gasket,fix a couple of electrical issues(fixed rpm sensor wire but cannot get fuel gauge to work.....karput)fixed leg on awning...car dash still in pieces but need to order a part....
    Fuel gauge or temp gauge?
    '92 (MIGHTY) GQ ST 3.0L Duel Petrol / LPG, 2" Pedders Suspension Lift on 33x12.5x15 BigHorns
    Lukey 2.5" Performance Exhaust with Extractors, snorkel
    Auto Lokka In The Front, Duel Batteries, Stiff Deep Dish Steering Wheel,
  4. The Following User Says Thank You to Rustyboner81 For This Useful Post:
    Avo (19th January 2014)
  5. #3183
    Jan 2013
    Bought some flogged simexs to see how 35s fit.
  6. The Following 2 Users Say Thank You to Dales300exc For This Useful Post:
    BigRAWesty (19th January 2014), growler2058 (19th January 2014)
  7. #3184
    Quote Originally Posted by Dales300exc View Post
    Nice. What lift is that?? Any scrub??
    Jan 2013
    Rears look like they should clear ok. Still heaps of room in rear guard before they hit in that pic bearing in mind it still has a fair bit of flex left in it. But they are probably 20mm bigger when new. Fronts will be fine with radius spacers. Its a basic 3 inch lift.
    Still a substantial increase from my 33 mtzs
  9. #3186
    Advanced Sonterr's Avatar
    Jan 2014
    Brisbane Northside
    Fitted my LH rear lights unit which my car seller ordered for me, turns out the bracket and globes weren't stuffed as he said but instead the wiring to the lights are just f*#ked..
    All my interior lights also stopped working to.. joy.. I hate electrics.
  10. #3187
    Patrol Freak gaddy's Avatar
    redlands
    Worked out why my break light fuse kept on blowing , just nicked a wire to the barn door brake light when I put the table on DOH
  11. #3188
    Legendary timbar's Avatar
    Feb 2011
    perth
    Dropped the patrol at the lpg repairer today to get my tank tested and re stamped ...... Next step is the pits and should pass first time woo HOO should be back on the road by the end of the week all goes well !!!!!
    1989 GQ LPG / PET TB42 LWB WAGON 4'LIFT 33's
    WELCOME TO THE MUD PITT WE DRIVE NISSAN PATROLS
  12. The Following 2 Users Say Thank You to timbar For This Useful Post:
    Clunk (20th January 2014), Stropp (20th January 2014)
  13. #3189
    Unafordable
    4 Post(s)
    Replaced dodgy IC fan temp switch (I really need to do something about that adjustable unit I have built from Jaycar)
    and
    Added another earth lead/strap, never enough on Patrol, LOL
    Quote Originally Posted by 93patrol View Post
    Also out of curiosity what style of aerial did you use? Stranded cb one or is there a propper am fm one??
    Just watch out with radius spacers that the panhard bolt doesn't collect the steering Rod when flexing..
    I Did read somewhere here of this happening when they fitted drop boxes and got sent spacing drop boxes..
  15. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Dales300exc (20th January 2014)
