Page 307 of 1057 FirstFirst ... 305306307308309 ... LastLast
Results 3,061 to 3,070 of 10565
  1. #3061
    Finished off my front 12v outlet, straight to my Aux via a 30amp circuit breaker to 50 amp Anderson with cover.
    Gives me extra options at camp how I'll run camp lighting
  2. The Following 2 Users Say Thank You to threedogs For This Useful Post:
    mudnut (27th December 2013), Stropp (27th December 2013)
  3. #3062
    Patrol God Stropp's Avatar
    38 Post(s)
    finally received my crosscountry intercooler, now the fun can begin with the td05 16g large and intercooler fitting
  4. The Following 2 Users Say Thank You to Stropp For This Useful Post:
    threedogs (27th December 2013), Winnie (27th December 2013)
  5. #3063
    Feb 2011
    Shed
    45 Post(s)
    Modded my dodgy storage drawers so the kid seat fits in the back
  6. #3064
    Expert Ian2011's Avatar
    Sep 2011
    Australia
    whacked in a new set of front speakers, now to get some more for the rear
    6.5 Chevy, roof rack, uhf, Spotties, dual batteries, ARB Bullbar, 12, 000lb winch, (unfortunately not Warn) Safari snorkel, Dieselgas conversion, 2in lift, engine watchdog fitted, boost/EGT guages, front elokka fitted, rear power supply mods, turbo timer, dual wheel carrier rear bar.
  7. #3065
    Unafordable
    4 Post(s)
    Replaced intercooler fan, what a fcuk up. Hopefully I don't have to touch it again....
  8. #3066
    @ Rumjas whats the probe thingy on bottom right of pic.
    Is that a boost sensor??
  9. #3067
    Unafordable
    4 Post(s)
    That's surface mounted temperature switch (50°C) to turn intercooler fan on when temp is right. I'm actually planning to fit air temp sensor inside intercooler boosted air stream aka MAT to get it more accurate than use Jaycar temp switch to create high/low settings.
  10. The Following User Says Thank You to Rumcajs For This Useful Post:
  11. #3068
    Quote Originally Posted by Flo-w View Post
    Finally had all the parts together and the time to fit them: 100l water bladder between storage system and rear seats, 4l/m self priming pump, hose to rear of car, key-switch for flat mounting so that it fits between storage system and barn door.
    pics!! We need Pics Please!
  12. #3069
    Quote Originally Posted by Rumcajs View Post
    nice! will that be affected by under bonnet temps or is it reading the surface temp it is stuck too? did you buy that from Jaycar?
  13. #3070
    Unafordable
    4 Post(s)
    It can/it is especially under heat soak temp conditions.
    NO, I didn't buy it, my CC intercooler is late type they started fitting them standard unlike early units.
  14. The Following User Says Thank You to Rumcajs For This Useful Post:
    MudRunnerTD (27th December 2013)
