Results 1 to 10 of 36
Thread: Fuel Guages
Threaded View
  1. #13
    brisbane
    Quote Originally Posted by rafa View Post
    I have been thinking more about when mine started to go wrong, my auto electrician wired in a red arc dual battery system to the third battery in the pod to charge while driving, from the second battery under the Bonnett, he ran a heavy duty positive wire to the third battery, then earthed to the pod. I noticed over the last couple of weeks that the third battery was not charging properly, He has comeback saying may be earthing to the aluminium body was not satisfactory. And has run a heavy duty her back to the chassis. I think this is around the same time that my fuel gauges were mucking up, could it be a coincidence? I am yet to see the error come up with the fuel gauges with the new earth, I will post more later
    With 3 batteries each earthed individually surely its not an earth issue, well not on the battery side
  2. The Following User Says Thank You to megatexture For This Useful Post:
    rafa (1st December 2013)
