Results 31 to 36 of 36
Thread: Fuel Guages
  1. #31
    178 Post(s)
    Some Feedback.
    It’s taken a while because I don’t yet clock up a lot of kilometres in my Patrol.
    I fitted a heavy duty extra battery to chassis earth cable as Yendor suggested & have now run a full tank of fuel through the motor. I am most pleased to report that like Rafa’s experience, the additional earth has fixed the problem, & my fuel gauge now reads ‘normally’ It’s great to once again have a gauge I can rely on.
    Thanks Rodney.
    Cuppa
  2. The Following 2 Users Say Thank You to Cuppa For This Useful Post:
    rafa (25th February 2014), Yendor (25th February 2014)
  3. #32
    Aug 2011
    River Heads Q
    4 Post(s)
    Had same issue until dual battery under the tray was earthed back to the block where main battery was earthed. Previously it was only earthed to steel frame under aluminium tray. No problem since.
  4. #33
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Some Feedback.
    Thanks Rodney.
    Cuppa
    Thanks for the update Cuppa, Glad to hear it has sorted your problem.
    Now all we need to do is get Darren to fit his and see if it fixes his remote problem.
  5. #34
    Hardcore
    central coast nsw
    This was posted on the other Patrol forum. It was taken from a Nissan Learning Manual.
    Those guys that are also having trouble with their keyless entry not working correctly may also want to try adding this earth.
    Cheers Rodney
    Rodney, can I get my hands on a copy, Nissan Learning Manual?.
    looked through manuals here, didn't see it listed.
    tar Robo
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
  6. #35
    Expert GU CAMPER's Avatar
    Sheffield Tasmania
    I have been having the same problems
    Yesterday I put an extra earth from the crank battery to the chassis as Yendor had suggested and Cuppa has done. The fuel gauges worked perfectly today so far. Fingers crossed it has solved my problem to
    NEVER USE A SNATCH STRAP ON A TOW BALL AS DEATH MAY RESULT
    GU 2005 Cab Chassis Ex Telstra POD, Set up for Remote Touring and Play
  7. #36
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    tar Robo
    Sorry for the late reply mate.
    Todd has informed me it is listed on this forum (I couldn't find it either)
    Here's the link http://www.nissanpatrol.com.au/Y61-CRD-TM1.pdf
