Page 67 of 177 FirstFirst ... 6566676869 ... LastLast
Results 661 to 670 of 1768
Thread: Ask all your general ( none related forum ) computer questions here
  1. #661
    Thank you gents, I feel somewhat slightly better...lol
    I am a software bloke not hardware so I struggle with this.
    Ill take it to my friend tomorrow and spend tonight in the fetal position praying the information is still there.
    Ill turn it off now as I have been known to try and DIY fix ups and make things worse...lol
  2. #662
    No back up, I'm an idiot!!!
    Yes you are!!
  3. #663
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Yes you are!!
    x2.... i got two backups but thats only because my life is obviosly more important than andys.
    Hello from Under Down Under!
  4. The Following User Says Thank You to taslucas For This Useful Post:
    Winnie (28th October 2013)
  5. #664
    Well la di da look at mr I am so perfect...lol.
  6. #665
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Second question...what can I do in safe mode to try and find and fix this problem. This poor old clunker has had a hard life!!!
    I'm no computer guru but try booting to command prompt only, majority of the time its the F8 key to give you booting options then run Chkdsk
    or boot up in safe mode and run Chkdsk
    I have had it happen before and I have always recovered from it.
    The other thing to try if you have a spare computer 2 use is run your HDD as a slave 9 times out of 10 it will recognize its got an error and run the Chkdsk anyway
  7. #666
    Advanced Fry's Avatar
    Sep 2013
    WA
    Just to clarify a repair reinstall of windows xp will leave all user files and programs as is but will reset windows.
    I use to do it all the time easy as fix.
    Quick google have a read of this https://forums.malwarebytes.org/inde...howtopic=61918
    "For example, if you killed your grandfather, you'd cease to exist!"
    ―Professor Farnsworth
    "But existing is basically all I do!"
    ―Fry
  8. #667
    Aug 2011
    North West Tas
    56 Post(s)
    i'll have to charge you for looking too long
  9. #668
    Ok so I'm assuming its not a good idea to leave computers on all the time in case or black outs or surges or solar flares which are apparently due soon and will bring us back to the Stone Age shortly????
  10. #669
    Aug 2011
    North West Tas
    56 Post(s)
    id guess it would give it a chance to do auto updates occasionally and also let it have a little rest
  11. #670
    Aug 2010
    17 Post(s)
    You should run your computers thru a surge protector / battery backup and should have decent cooling if leaving them on 24/7
  12. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
    AB (28th October 2013)
