Page 66 of 177 FirstFirst ... 6465666768 ... LastLast
Results 651 to 660 of 1768
Thread: Ask all your general ( none related forum ) computer questions here
  1. #651
    Advanced jackwalks's Avatar
    Warner, Brisbane
    Black screen of death help me!!!
    I leave my computer on 24/7 but we had a black out today. Just got home and it won't start. Goes through the usual start up but before windows start the screen just goes black but you can see the mouse cursor.
    It wants to do a disk scan, I press ok, same thing happens above.
    Then I tried to boot in safe mode which works fine and then restarted computer in normal mode same problem as above but it says cannot open volume for direct access when I try to run a disk scan on start up.
    If I try to start comp without running disk check same problem as the start.
    My question is...help me please!!!
    Second question...what can I do in safe mode to try and find and fix this problem. This poor old clunker has had a hard life!!!
    Hiya AB, sounds like you have lost startup files...........The fix: If its a laptop, remove hard-drive, keep hard-drive, then bash-burn-bury laptop. buy a new one and externally connect HDD to gain access to files.
    If you have a newish desktop computer: remove hard-drive, and install a new HDD, format and load windows. Once again externally access your old HDD via cable and gain access to your old files.
    If its an old desktop computer: bash-burn-bury
    2001 GU II - 3.0TD Auto. ARB Bullbar - Runva 11XP Winch - NADed with Boost & EGT gauges - OME 2in Lift - Manta 3in - Dual Battery - Spotties & LED Lightbar - Uniden 80ch UHF - Rear Drawers & Engel Fridge - 3/4 Steel cage Car goes vroom
  2. The Following User Says Thank You to jackwalks For This Useful Post:
    AB (28th October 2013)
  3. #652
    Quote Originally Posted by jackwalks View Post
    PC desktop...
    I really don't want to hear that mate.
    I have my life on there, my emails, my program's my everything!!!!
  4. #653
    Advanced Fry's Avatar
    Sep 2013
    WA
    do you run Windows mate and if so what version? I.E Windows XP, Vista or Windows 7
    "For example, if you killed your grandfather, you'd cease to exist!"
    ―Professor Farnsworth
    "But existing is basically all I do!"
    ―Fry
  5. #654
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    PC desktop...
    What o/s Andy???
  6. #655
    Aug 2010
    adelaide
    my screen kept going blank and turned out to be hibernation was set to 1 minute
    some update changed it
    OH LEATHER IS NICE
  7. #656
    Sorry boys, yeah old xp
  8. #657
    Quote Originally Posted by my third 256 View Post
    Nah it's not that mate, it's during loading windows but windows doesn't load.
  9. #658
    I just spoke to my friend ill drop it off tomoz to him and pray. He said as long the drive hasn't fried we can get info off and ill just get a new computer.
    I'm so stressed...lol
    So much info, so many program's I have collected!!!
    Contacts, emails, info!!!
    No back up, I'm an idiot!!!
  10. #659
    Warner, Brisbane
    AB, 2 things:
    The following errors occurred with your submission
    AB has exceeded their stored private messages quota and cannot accept further messages until they clear some space.
    Clear your inbox, im was trying to send you a PM
    2ns thing. By taking out your old hard drive and using a new one, you do not loose anything at all. You can gain access to all your 'life' on your old HDD. But I would use a new HDD to install a fresh install and then once everythinf is working well, transfer your 'life from your old HDD to the new one. Then you can format the old disk and use it as a backup drive.
    I hope I sound clear in the above
  11. The Following User Says Thank You to jackwalks For This Useful Post:
  12. #660
    Sep 2013
    WA
    Repair reinstall usually fixes XP issues, as long as the Hard Drive is ok.
    but yes I recommend backing it all up onto another computer first.
    ―Fry
  13. The Following User Says Thank You to Fry For This Useful Post:
