Quote Originally Posted by davo94 View Post
1-Confirm fuel pressure
2-confirm fuel supply rate of flow
Does it start better if you prime the High pressure pump by cycling the reds on and off 3 or so times?
Does it start better when warm?
Pezzer said that the miss goes away with higher revs. Would a fuel supply or pressure issue do this or would it get worse the higher the revs?
How old are the plugs pezzer?
