I will be installing my boost gauge soon, hopefully in a week. Mine is a manual 3.0Di stock, I will report back if mine produces boost or not in neutral.
Lemo.
2006 GU IV ST 3.0L TD Di
Autron Boost and EGT, Dual Bat, Dawes & Needle Valves, ARB Alloy rack, more to come.
Yeah it's perfectly normal. Performance wise if I could have 5psi even 10 at idle then it would make for a very quick td
No you should see more!! There are setups out there which can produce near on 30psi by 2000rpm on a td42 and can hold that til nearly 4000rpm. They make for a very drive able and responsive vehicle.
Nothing wrong with making boost at 500rpm (although that is a little low for a TD. Seeing boost at 1000rpm is good though and correct turbo sizing won't see you top out to early.
True! But I'm making the assumption its a stock setup.
Fair enough.
