Results 1 to 10 of 28
Thread: Antonio from Angola
Threaded View
  1. #23
    Patrol Freak trekster's Avatar
    Nov 2012
    Coffs Harbour, NSW
    Quote Originally Posted by Antonio View Post
    Thanks,
    I will follow up this issue, at the request of the owner and friend, and report on this forum.
    The owner wishes to make sure the car is repaired properly and that he is not, again, victim of another fraudelent repair.
    Thanks for the input.
    A simple compression test would give you an idea, then if that is good you could pressure test the cooling system and see if there is something amiss there.
  2. The Following User Says Thank You to trekster For This Useful Post:
    Antonio (29th July 2013)
