Page 7 of 7 FirstFirst ... 567
Results 61 to 65 of 65
Thread: Your winch is it any good
  1. #61
    Oct 2011
    Essendon
    Thank mate. Much appreciated!
    Tip tip tip......tap tap tap....
  2. #62
    Quote Originally Posted by Drewboyaus View Post
    Daz,
    What did you do to bench test it? Eg; how did you set the test up?
    Was going to start pulling mine apart tonight to have a look.
    Where did you get your Superwinch parts from (if you needed them that is)?
    Cheers,
    Drew
    Hi drew,
    I used a jump pack to power the winch without the solenoid.
    You will find the power sequence via google and power up the winch and test the directions are working well.
    I did into need any parts as it all just needed a good clean out. Most parts though should be readily available Drew.
    Give me a yell any time
    Hey Drew try this mate
  3. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    mudnut (30th May 2013)
  4. #63
    Oct 2011
    Essendon
    That's great. Thank mate.
  5. #64
    Beginner droppa's Avatar
    Feb 2012
    how do u match a winch to a trol, like will a 8K be good for a mk/mq??
  6. #65
    Quote Originally Posted by droppa View Post
    i think you should be starting at a 9k winch unless its a High Mount
