Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 65
Thread: Your winch is it any good
  1. #51
    Quote Originally Posted by droppa View Post
    anyone using superwinch here? XRC 10?
    what about winch care, hoe do u guys care for your winch?
    I have an X9 superwinch on the GUiV. I bought it second hand and it looked unused. It had been on the front of a 200 series and when I got it home I bench tested it. It was fully seized and rooted.
    I stripped it down and rebuilt the gearbox and then the motor as both had been full of water and were solid.
    Don't take it for granted that the winch on the front of your car for 5 years and never used will still be ok to use. Test it, service it at least once a year. It's not hard to do and take a couple of hours and then will not let you down when you really need it.
  2. #52
    So MR you cut your grill to fit the 8274, Did you ever see Flamin fabs twin motor mod and extended spool.
    Think he did one for Birdie and Co
  3. #53
    Yeah I like allot but just more cash! Thinking of going a. Extended drum and air free spool
    Would be nice
  4. #54
    From memory didnt one of the guys pressurize motor with Air to stop water and help cool as well.
  5. #55
    Yes I have that setup on mine but have not really used it to be honest so it acts like a vent when not pressurized. Pressurizing is actually quite difficult to achieve but I do at least get positive airflow (pressure) but it is also well sealed.
    If I go the air free spool then will use that airline and solenoid to operate the free spool and do away with the pressurize option.
  6. #56
    22 Post(s)
    My winch will be good when I pick it tomorrow. Warn hi mount for FREE!!!!! just need to put it back together and find a remote, then it will run. Then I'll upgrade the solenoids and free spool and some dyneema.
    96 GQ coil/Cab
    08 G6eT
  7. #57
    Expert Forced Offroad's Avatar
    Apr 2011
    Logan/Daisy Hill
    Nice score,
    Here is a good company if your wanting to rebuild your highmount.
    http://smithiengineering.com.au/index.php/
    FORCED OFFROAD
    Built by NISSAN Powered by HOLDEN Perfected by ME "hulksta"
    http://www.youtube.com/watch?v=3GX2M...layer_embedded
    http://www.nissanpatrol.com.au/forum...Gq-v8-daul-cab.
  8. #58
    Oct 2011
    Essendon
    Daz,
    What did you do to bench test it? Eg; how did you set the test up?
    Was going to start pulling mine apart tonight to have a look.
    Where did you get your Superwinch parts from (if you needed them that is)?
    Cheers,
    Drew
    Tip tip tip......tap tap tap....
  9. #59
    Hi drew,
    I used a jump pack to power the winch without the solenoid.
    You will find the power sequence via google and power up the winch and test the directions are working well.
    I did into need any parts as it all just needed a good clean out. Most parts though should be readily available Drew.
    Give me a yell any time
  10. #60
    Thomastown, Melbourne
    6 Post(s)
    I'll drop off the crane on saturday drew for you and you snatch strap.
    Makes the job so much easier!
