High mount, but ill probably piss that system off and go electric if I had my way...
Nearly ready to go Friday.
Owner of
Westy's Accessories
Owner of
Westy's Accessories
Well i thought i betta up date...
So i have ticked a few boxes on the to do list..
Dual batteries done..
Fridge Done, yet to fit slides but coming..
Draw system and cargo area.. DONE (<<Link)
And now the LED lights for that area.. DONE..
I saw the ideal spot to run the LED strip.. There is a 8mm gab between the outer / lower door jam and the door itself.. So why not..
Drilled a hole in the panel to allow wire to run threw, and ran the wire down the internals of the pillar to the jack location and then into a switch which i have built into the draws system..
If you remove the outside vent panel this give access to the inside of the pillar and aids in running the wire down.. Very happy..
The gap
Owner of
Westy's Accessories
Nice LED'S mate, I really like that slide out table. Good looking GQ
Troy
1998 GU TI LS1
BigRAWesty (7th May 2013)
Cheers mate. A bit to do to get it back. Rust removal and tint is next up..
Owner of
Westy's Accessories
R u referring 2 the nissanpatrol.com.au stickers?????
If so check this thread out: http://www.nissanpatrol.com.au/forum...om.au-Stickers
Taslucas knocked me up an awesome set of stickers. Not 100%. sure if he's still doing them.
Tappin trolls
Brendan
If you're following this Patrol, Stop... You're not gonna make it
Cheers fellas
