Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 51
Thread: Westy's Ride
    Re: Westy's Ride
    High mount, but ill probably piss that system off and go electric if I had my way...
    Nearly ready to go Friday.
    Owner of
    Westy's Accessories
    Well i thought i betta up date...
    So i have ticked a few boxes on the to do list..
    Dual batteries done..
    Fridge Done, yet to fit slides but coming..
    Draw system and cargo area.. DONE (<<Link)
    And now the LED lights for that area.. DONE..
    I saw the ideal spot to run the LED strip.. There is a 8mm gab between the outer / lower door jam and the door itself.. So why not..
    Drilled a hole in the panel to allow wire to run threw, and ran the wire down the internals of the pillar to the jack location and then into a switch which i have built into the draws system..
    If you remove the outside vent panel this give access to the inside of the pillar and aids in running the wire down.. Very happy..
    The gap
    Owner of
    Westy's Accessories
    Expert Thirsty's Avatar
    Oct 2011
    Raceview, Ipswich QLD
    Nice LED'S mate, I really like that slide out table. Good looking GQ
    Troy
    1998 GU TI LS1
  5. The Following User Says Thank You to Thirsty For This Useful Post:
    BigRAWesty (7th May 2013)
  6. #15
    Quote Originally Posted by Thirsty View Post
    Troy
    Cheers mate. A bit to do to get it back. Rust removal and tint is next up..
    Owner of
    Westy's Accessories
    Expert Frontbumfab's Avatar
    Troy
    X2
    Real neat draws mate
  8. The Following User Says Thank You to Frontbumfab For This Useful Post:
  9. #17
    Dec 2012
    Fits right in now..
    Where can I get one of these from?
  10. #18
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Quote Originally Posted by 4 by 4 View Post
    R u referring 2 the nissanpatrol.com.au stickers?????
    If so check this thread out: http://www.nissanpatrol.com.au/forum...om.au-Stickers
  11. #19
    Expert Brendan56's Avatar
    Townsville
    Taslucas knocked me up an awesome set of stickers. Not 100%. sure if he's still doing them.
    Tappin trolls
    Brendan
    If you're following this Patrol, Stop... You're not gonna make it
  12. #20
    Dec 2012
    Cheers fellas
