Page 31 of 52 FirstFirst ... 2930313233 ... LastLast
Results 301 to 310 of 518
Thread: Toughest Patrol??? GQ or GU
  1. #301
    Legendary Alitis007's Avatar
    15 Post(s)
    At the end of the day GU's rule !!! FTW!!!!
  2. #302
    Expert oilpond's Avatar
    Over here!
    Your GU is shit and your a wanka...
  3. #303
    22 Post(s)
    The power that my setup will produce will have no affect on any suspension components unless i choose the wrong spring and damper rates then my handling and drivability will be compromised. The weak link could be the actual motor i choose to run.
    The cars at wreckers are usually rolled or flood damaged vehicles and cars that have been wiped out on the rd and anyway they just scrap GQ bodies coz they're rusted out anyway.
    So you just said that you need GU's to make GQ's tougher !!!!!!!
    so obviously you are not going to run a td42 lmao
    yes gu parts CAN make a GQ tougher although it isnt necessary, its just that a GU had to die to supply a gq that is still living.
    think of it as organ donation.
    as for rust I have seen some heavily rusted GU's it is not a problem with GQs only
    96 GQ coil/Cab
    08 G6eT
  4. #304
    22 Post(s)
    Depends on what mods are done, upgrading to thicker controls arms is more like an upgrade than a modification, cutting a dirty big hole in your bonnet for an intercooler makes it weaker by removing its reinforcement, not a upgrade thats a mod!
    than what about my long arm kit.
    96 GQ coil/Cab
    08 G6eT
  5. #305
    15 Post(s)
    Don't know what that is lmao
  6. #306
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    And there ends the discussion:-)
    FanTapstic!
    Hello from Under Down Under!
  7. The Following 2 Users Say Thank You to taslucas For This Useful Post:
    Ben-e-boy (1st May 2013), Maxhead (1st May 2013)
  8. #307
    SUCH IS LIFE Maxhead's Avatar
    ACT
    ________________________
    ______ 2017 D-Max _______
  9. The Following User Says Thank You to Maxhead For This Useful Post:
    Alitis007 (1st May 2013)
  10. #308
    15 Post(s)
    Thanks Kris!!
    Only problem i can see with the long arm kit that i can think of is what affect in the long run does it have on the chassis?? Will it crack along the weld after a beating ? To get your tail shaft on that sharp angle under full flex doesn't that tube that runs across the chassis near the handbrake drum have to be cut?? Wouldn't you loose its integrity and possibly twist your chassis?? What affect does all that flex do to the canceling angles of the universal joints under full acceleration, wont they chop out or twist the tail shaft??
    So you've got killer flex but just weakened the truck!! IMO
  11. #309
    22 Post(s)
    Thanks Kris!!
    Righto... firstly define beating.
    did you read the page about the problems it corrects?
    96 GQ coil/Cab
    08 G6eT
  12. #310
    Quote Originally Posted by Bob View Post
    Nobody and I mean Nobody is going to win this discussion LOL
    But it is keeping some of you busy LOL
    Spoken by a true gu owner.... Lmao
    Don't forget the gq has stronger gearbox and earlier td42 silver top have stronger conrods.
    At the end of the day so far in all of our meetups when we split up the group the gq's head that way and the gu owners head down into the valley for some scones and cream.
    Except for Nisspat who buys a brand new patrol and takes it out like a paddock bomb...lol...respect!
  13. The Following 3 Users Say Thank You to AB For This Useful Post:
    Ben-e-boy (1st May 2013), taslucas (1st May 2013), Winnie (1st May 2013)
