Results 1 to 10 of 26
Thread: Newnes - Pipeline track. Where is it?
Threaded View
  1. #8
    Patrol Freak hekarewe's Avatar
    Feb 2011
    springfield lakes
    Quote Originally Posted by DSzuke View Post
    The Pipeline Track I'm familiar with is a short section close to Lithgow.
    You literally drive up an old pipe like a rock step, hence the name.
    Most of the u-Tube vids appear to be that track.
    If you can pick it, it is only a couple kms out of lithgow on the glow worm rd.
    DSzuke your spot on with the pipe line also known as "hills to now where" if you dont want to damage your truck DONT do it and take my advice i have done this track on many occassions when i still lived in sydney dont try and drive down always go up this track its the only safe to do it be prepared for some road building about half way up this track at the big step and directly after it is a sharp rock with point on it that is sill hight an has opened cars like tin cans last time i did this track was easter last year i have add links to the in car cam i use showing how bad it was last year when i did it the landcruiser i was with lost all his guard and farings on the right hand side when he climbed it. i found the easy way to find this track is head toward the glow worm tunnel rd from zig zag, when you get to the glow wirm tunnel rd turn left and follow untill you start heading down the pass to lithgow you will come around a tight left hand bend with a parking area/clearing on the right look hard left and you will see the track turn hard left and be in 4wd as you will wheels of the ground with in the first couple of meters or it was like that last time i was there as you enter it you will see a track in front of you with a rock step and the main track will turn right follow it around to the right walk it first and watch the wash outs at the top oh yes and GOOD LUCK!!!!
    post up some footage if you do it
    http://youtu.be/07foO0nN-pM
    http://youtu.be/kAgteT7UrpE
    http://youtu.be/OfBbfKbnNLQ
  2. The Following 2 Users Say Thank You to hekarewe For This Useful Post:
    NissanGQ4.2 (29th April 2013), Remmy (4th June 2013)
