Alitis007
Just making a list of the parts we will need and would like to have for our Member on hard times thread. Theres going to be a wish list or goodies list and a need list that i will be updating as we go along.
PLEASE ONLY POST HERE IF YOU HAVE PARTS THAT YOU WILL LIKE TO DONATE OR THAT YOU THINK WILL BE A GOOD IDEA FOR THE GOODIES LIST!!
The car is an 01 GU ZD30 ( Built date 6/2000)
WHAT IS NEEDED
GEARBOX / synchromesh kit (4th gear ) - ordered
Clutch kit - received
Rear main seal OEM - received
Rear diff - donated by 4WD Obsession
Recovery points - donated by Threedogs
Battery - donated by Mudski
Oils : Front diff 80w90 up to 5.4 liters -
Rear diff 140w ( or 85w140) up to 4.7 liters -
Transfer case TX12A ( 75w90) 1.9 liters -
Gear box TX12A (75w90 ) 3.5 liters -
2 X Swivel hub kits and bearings ( bearings felt good but need to look for pitting and metal filings ) - 4WD Obsession
Rear stabilizer bar link rods, long and short ( 2" lift) -
Rags, rags, RAGS!!!! And paper towel - Healy, BA
HTB / High Temp Bearing grease -
Brake fluid ( DOT 4) - 2 X 500ml -Plasnart
CV / Constant velocity grease -
Cable ties, heatshrink, tape and bullet crimp connectors - Winnie
200 odd adhesive backed cable tie mounts, 2000 cable ties and 30m each of 2 sizes of split conduit - Drewboyaus
Climate control with cables - ordered
SAFETY EQUIPMENT
Jack stands - MR 1 set
Trolley jacks - MR 2 x 2000kgs jacks
Wheel chock's -
Safety glasses - MR has Heaps
Gloves ?? Leather and silicon / rubber - MR will bring a box of Nitriles (100)
Hand cleaner ( Good stuff/ Jiff works too) - Alitis007 (i can get some for free but won't be to AB's till late)
WISH / GOODIES LIST
To be revealed - Westy's accessories
Rear work light with mounting stand -
Rock sliders (the ally side steps look fantastic ATM) -
Wheel arch flares and rear bar with moulded flares (sorry mate it looks anorexic lol) -
Spotlights ( who was showing them off the other day ????) -
Tools
Like i said i will add more to this list daily!
Thank you for all your help and support!!
And a big thank you to Bloodyaussie / Jonathan for organizing this special event!!
