Page 124 of 1057 FirstFirst ... 122123124125126 ... LastLast
Results 1,231 to 1,240 of 10566
  1. #1231
    Western suburbs of Melbourne
    12 Post(s)
    What did you do to your Patrol today!
    I was drifting on the wet roads, holding a controlled drift around a roundabout, scary but fun.
  2. #1232
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Cracked the brake light cover jack knifing the box trailer into the car port ..........ooopppppssssssssss
  3. #1233
    Oct 2011
    Essendon
    Filled it with water in a bog hole!
    Tip tip tip......tap tap tap....
  4. #1234
    Re: What did you do to your Patrol today!
    Oww noooo
    Owner of
    Westy's Accessories
    178 Post(s)
    Removed the wire winch cable & roller fairlead & fitted the Dyneema & alloy hause. Knocked off just over 13 kg & feel a lot safer 'playing' with the winch now.
    I reckon the wire cable must've been pretty new when I bought the vehicle, it was in very good condition. I'd expected it to be curl up & become unmanageable when laid out on he ground, but it just laid flat behaved itself.
    When things were happening slower as I got closer to the tree I was winching the vehicle to, I thought briefly that the battery might be going flat, until I remembered that pulling power reduces with each layer on the winch. Phew!
    Cuppa
  6. #1236
    Trust you did the first two rows tight then from side to side fast for the rope p
    As for your old winch cable take it to a cable shop and get eyelets fitted both ends
    cost is very minimal and makes a great extension cable if needed
  7. #1237
    Oct 2011
    Essendon
    Quote Originally Posted by Drewboyaus View Post
    Was bloody fun doing it too.........
  8. #1238
    Went for a drive to Grovedale Geelong to pick up a redgum slab.
    Having just filled it will now work out my fuel figures, its a 100kph
    both ways most via fwy.
  9. #1239
    brisbane
    Put a new sway bar in after I broke the old one .... Apparently the missus didn't feel safe with the body roll
  10. #1240
    Expert nickpeacock36's Avatar
    Oct 2010
    North Lakes Qld
    Admired it as i drove off to work Weekend work should be banned
    Sent from my GT-S7500T using Tapatalk 2
