Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Strange knocking sound
    Jan 2013
    Greetings
    I was driving from Sydney to Newcastle the other day and when I came off the motorway, a strange knocking sound that sounded like a CV joint starting coming from under the driver wheel when I did left hand turn on roundabouts and corners. However, when I got home, I went out to refuel a few hours later and the car would not make the sound again. I was wondering whether it was due to driving two hours straight on morotway and something got hot. Does this sound possible or what do you think it might be?
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    Does it have manual freewheeling hubs? I'd assume that there shouldn't be any cv movement if you're driving in 2wd and have the hubs disengaged.
    Legendary 93patrol's Avatar
    Dec 2012
    Bunbury
    when was the last time you had your wheel bearing done?
    Patrol Guru Lonicus's Avatar
    Tewantin QLD
    Sounds like one of those pesky cyclists and he managed to pry himself loose once you'd stopped for a while
    2012 GU8 ST 3.0 CRD. Alloy bull bar, HID spotties, Pioneer GPS/CD/DVD head unit, Beaudesert 2.75" exhaust, Autometer Boost and Pyro gauges.
    WARNING: Towballs used for recoveries can, and do, kill people and damage property.
  5. The Following 2 Users Say Thank You to Lonicus For This Useful Post:
    BearGUST (21st February 2013), GQPorkroll (11th March 2013)
    Jan 2013
    The whole front end was done about a year ago by previous owner (my brother - a mechanic) and it has not been offroad. He said he noticed the noise before he did front end. He jumped on it and did everything and could not find the noise.
    CV joints have been repacked, wheel bearings done, new shocks, new sway bar. He said the sway bar was not genuine, so it could be because of that. I will keep an eye (or rather - ear) on it.
    Dec 2012
    Bunbury
    could also be loose/worn ball joints on your steering arms sometime they knock when too loose
    CV make a clicking sound when you turn corners.
    What you are saying doesn't sound like CV's
    What are you driving by the way.
    In order for members here to assist you they need all the info you can give them
    84 Post(s)
    Yeah, I have had that same sound come and go. I took the trol to a mech and he put it on a hoist and we looked for a problem. The only thing we found was that there was a very small shiny edge on the front left hand brake disc. Which indicated that a stone must have become wedged somehow. The sound went away for a couple of months, but yesterday, I did a hard right hand turn and the Knocking noise came back at the apex of the turn, then stopped... Weird or what. Mine has manual hubs and both front wheel bearings have been repacked recently.
  10. #9
    Re: Strange knocking sound
    Body or engine mount?
    Don't stroke it, TAP it!!!!.....
  11. #10
    84 Post(s)
    Nah, mate, definitely a rotating part. Too much grease in hub lock? But I think that would make the hub pull into lock position wouldn't it.
