Results 1 to 10 of 17
Thread: LH high beam not working
Threaded View
  1. #5
    Ok, I had this issue a while ago to. You have most likely burnt out the terminal inside the selector box in the steering colum..
    But start easy, check fuses first..
    If no good pull the colum apart, remove the light selector box, carefully remove the plastic lid, check the circuit.
    I bridged mine so left and right are now together.
    If your running high powered lights its best to run relays for them..
    Owner of
    Westy's Accessories
  2. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Conradk (21st November 2012)
