There are no factory fitted headlight relays.
If the low beam still works on the RHS and the high beam and the spot lights stopped working at the same time, More then likely you problem is with the contacts in the headlight switch.
They have a set of contacts for the LHS high beam and another set of contacts for the RHS high beam. You can pull the headlight switch apart and clean the contacts, you may also need to carefully adjust the contacts.
It is not a good idea to bridge the left and right high beam together, this will double the load going through the LHS switch contacts and the fuse.
If you are unable to repair the headlight switch you would be better off fitting relays.
I did have concerns, but after talking to my elecy friend and showing him he deemed it ample for the stock lights..
If your running higher wattage high beams then either replace the unit, or bridge and use relays to supply power to be sure.
8 months now and mine is still working..
Owner of
Westy's Accessories
