Results 11 to 20 of 23
Thread: Provent drain line and tap
    brisbane
    Quote Originally Posted by roofy View Post
    Hi fellas
    have noticed of late that a lot
    of guys asking where to run there
    drain line from the provent200
    some run the oil back into the sump
    i run mine to under the body with a
    tap attached and drain it this way
    its usually black and smells burnt
    its just engine fumes gone back to
    solids again and the most i have
    measured is 60ml over a 3,4 month
    period
    THIS WORKS FOR ME,AND IS EASY TO GET AT
    x 2 on that ive done the same though my tap is on the catch can and hose runs down to empty it easly without removing it i wouldnt want the crud going back in either.
  2. #12
    Patrol Guru White Elephant's Avatar
    Sep 2011
    Perth,WA
    Interesting to see the differeing opinions. I am fitting mine to a 95 GQ RD28T just so we're all clear. I have noticed oil on the inlet side of the turbo(not turbo seal because it has not long been rebuilt) So the only place it can be coming from is the breather.
    95 GQ RX RD28T LWB Wagon and stuff. www.levelsevenband.com
  3. #13
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Quote Originally Posted by White Elephant View Post
    fingers crossed this will fix the oil problem and you,l notice your engine will run free,er
    hope you get back to us after you,ve done it
  4. #14
    I just ended up running mine straight down below the Provent and shoved a half inch bolt in it with a hose clamp on it. That looks like too much work Roofy.
  5. #15
    TRAFALGAR VIC
    35 Post(s)
    have fun draining that when the time comes
  6. #16
    I think this might be another one of those things I'd like to do. Plan to do. But will be interesting to see if I ever get around to doing!
    On another note. Does anyone ever actually change the filter? Or just drain the oil out?
    Cheers, Teno.
    Teno's Troll...
    08 CRD ST. 2" lift, 33' Maxis Bighorns, Snorkel, ARB Deluxe Bar with Foggies, 12000lbs Avenger Mako TDS with Synthetic rope.
  7. #17
    Patrol Guru Drew's Avatar
    Western burbs of Melbourne
    Quote Originally Posted by Steveo_the_Devo View Post
    I get a lot LOT more than 60ml every few months. At least double that and then some. Wondering if I've missed something on the set up. I noticed there was no restrictor in my original line so maybe that is it?
    I didn't have a restrictor either. I get very little oil but collected a fair bit of water after the last oil change, drained that and now keeping an eye on it all to see if that's normal or not.
    Oh and nice job roofy
    2008 GU 3.0 CRD Auto - Life's too short to eat bad food.
  8. #18
    TRAFALGAR VIC
    35 Post(s)
    Quote Originally Posted by teno45 View Post
    i think this might be another one of those things i'd like to do. Plan to do. But will be interesting to see if i ever get around to doing!
    Cheers, teno.
    have,nt changed filter as yet but think if it got blocked just a rinse in kero
    would be enough
  9. #19
    TRAFALGAR VIC
    35 Post(s)
    Quote Originally Posted by drew View Post
    i didn't have a restrictor either. I get very little oil but collected a fair bit of water after the last oil change, drained that and now keeping an eye on it all to see if that's normal or not.
    water ? Was the top screwd on properly ?anydeep crossings lately
    mmm condensation from the rocker cover could be head gasket
  10. #20
    Sep 2011
    Perth,WA
    would be enough
    Sounds like a good plan mate, hadn't thought of a rinse with Kero. THe replacement filters are about $80 I think. But hey, if you can save $80 with a rinse in some clean kero, that would be the way to go!
