Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Provent drain line and tap
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Hi fellas
    have noticed of late that a lot
    of guys asking where to run there
    drain line from the provent200
    some run the oil back into the sump
    i run mine to under the body with a
    tap attached and drain it this way
    its usually black and smells burnt
    its just engine fumes gone back to
    solids again and the most i have
    measured is 60ml over a 3,4 month
    period
    Attachment 18319 Attachment 18320
    Attachment 18321 THIS WORKS FOR ME,AND IS EASY TO GET AT
  2. The Following 2 Users Say Thank You to Sir Roofy For This Useful Post:
    White Elephant (23rd July 2012), Woof (24th July 2012)
    Oct 2010
    Old Bar, NSW
    Thats an easy way around the problem of draining the oil, nice job Roofy.
    Cheers Macca
  4. The Following User Says Thank You to macca For This Useful Post:
    Sir Roofy (23rd July 2012)
    Nice one Roofy, I'll put a Pic of mine up later doesen't even look like catching any oil and its been 4 months or so
  6. The Following User Says Thank You to threedogs For This Useful Post:
  7. #4
    Patrol Guru White Elephant's Avatar
    Sep 2011
    Perth,WA
    Quote Originally Posted by roofy View Post
    Hi fellas
    period
    Thanks mate. It seems like this is what most would go for, I really did want to run mine back into the sump, just for oil consumption purposes, but if it's only minimal as you say, I might just go with this option. If I find that there is a substantial amount of oil, I might re investigate returning to the sump.
    95 GQ RX RD28T LWB Wagon and stuff. www.levelsevenband.com
  8. #5
    Patrol God Bob's Avatar
    Oct 2010
    Pakenham
    47 Post(s)
    Quote Originally Posted by White Elephant View Post
    I really dont know but would think that the Oil in the Catch Can would not be suitable to be returned to the Sump. As Roofy says smells burnt
  9. #6
    Sep 2011
    Perth,WA
    Quote Originally Posted by Bob View Post
    Considering that it is only vapour coming from the rocker casing at the top of the motor (that's where the PCV is located) I can't see why it would smell burnt unless the oil was really dirty and hadn't been changed for a while? Not too sure really, but if it's good enough to feed that vapour back into the inlet, it should be okay to drop back into the sump. My 2 cents anyway.
  10. The Following User Says Thank You to White Elephant For This Useful Post:
    Bob (23rd July 2012)
  11. #7
    Oct 2010
    Pakenham
    47 Post(s)
    Yeah as I said I dont really know. Would be interesting to see what others think.
  12. #8
    Advanced Steveo_the_Devo's Avatar
    Oct 2011
    Wollongong NSW
    I get a lot LOT more than 60ml every few months. At least double that and then some. Wondering if I've missed something on the set up. I noticed there was no restrictor in my original line so maybe that is it?
    2011 CRD with a bunch of stuff bolted on
  13. #9
    TRAFALGAR VIC
    35 Post(s)
    as i said some put it back into the sump,think chaz does,but why would you want to put dirty oil with diesel fumes
    back through your motor,the 3ls are sensitive enough with out jeapodising it further
    my set up is the rocker cover pipe goes to the top of the provent with a readucer placed in the hose
    these fumes go through the filter stopping any solids going back to the pvc then through the turbo
    ive posted once before that the M.A.F WAS BONE DRY and clean after that period of time as mentioned above
    cheers roofy
  14. #10
    TRAFALGAR VIC
    35 Post(s)
    Quote Originally Posted by Steveo_the_Devo View Post
    maybe thats why im not sure,but ive got the restictor in mine
    i read somewhere that they put one in for a reason SO why not use it but if you havent one then
    your not to know put one in and see if it makes a difference ,then let us know
