Results 21 to 30 of 33
Thread: Lockers ????
    The majority of the diffs are the same in the GQ and GU
  2. #22
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Really?? I have a set of 4.1:1 diff centres from a GU that I was told wouldn't slot into mine (as they are currently 3.9:1 centres). Happy as a pig in poo to be wrong ...
  3. #23
    They will go in Scotty no worries the diff centers are the same across the board except for the larger centre that went in the leaf rear. The only thing to check would be the spline count but I'm 95% sure it wil bolt straight in. We can have a go at the workshop day .
  4. #24
    Brisbane South West
    I have heard that if you fit an Auto Locker then you should look at fitting a radiator for the power steering due to the extra work that the power steering has to do. Any opinions on this, especially those that have an Auto Locker already.
  5. #25
    Feb 2011
    Shed
    45 Post(s)
    Couldnt hurt, though i havent had a drama to date
  6. #26
    brisbane
    Quote Originally Posted by oncedisturbed View Post
    Yup, front only for GU - both for GQ as per email I got from them
    So both gq front only gu... Figures wouldnt want anything to go my way for a change!
  7. #27
    Like I said earlier the centers are mostly all the same MT so I find it out they don't list it for a gu
  8. #28
    Their are three different gq rear diff centers look at an early gq lsd totally different to the later ones the one i pulled out of my 97 gq is a 4 pinion with sungears. and the h260 center easy to spot it has 12 bolts holding it to the housing instead of 11 and is huge.
    The one i removed from mine looks like this.
    and this is what the earlier ones looked like
  9. #29
    Feb 2011
    Shed
    45 Post(s)
    Quote Originally Posted by 97_gq_lwb View Post
    Like this
    Cant see the piccie mate
  10. #30
    Advanced silly one's Avatar
    Jul 2012
    so are auto lockers availible for the mk diffs leafs front and rear ????
