Results 11 to 20 of 36
Thread: anyone know what this dash light means? (GQ)
    Patrol Guru Ade's Avatar
    Apr 2011
    Sabah, North Borneo
    Yup..ATF temp warning light on an auto patrol. Maybe your cluster were from an auto patrol..
  2. #12
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    I would say your got an electrical prob, considering yours is manual
  3. #13
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    The ATF temp doesn't have a warning chime.
  4. #14
    Expert kiwijase's Avatar
    ^^^ thats what i thought Rodney
    if it aint hurting,it aint working.....1991 y60 LWB 24 volt TD42 Safari
  5. #15
    Aug 2010
    17 Post(s)
    Certainly doesn't, your the only one that said "I think some Safari models had a "don't forget to put your seat belt on" warning light and chime, maybe it's for that."
    Maybe you are right Rodney, one would think if the chime and light were related the blinking light would have a pic of a seatbelt
    The seatbelt warning light on my 92 GQ is located in the tachometer and does not have a chime
    adimw, do you have a seatbelt warning light that flashes at the same time as the chime?
  6. #16
    Don't think I have a seatbelt reminder, and on the printed material of GQ dash clusters I have it only shows seatbelt sign on the left side of the cluster. Meh, its stopped chiming and I'm ignoring the flashing light, it still takes me everywhere I point it and runs as normal bar that light.
  7. #17
    Take the bulb out in the back of the cluster.
    Maybe someone has tapped into it for some other use i was going to set mine up to my egt gauge using one of the unused warning lamps in the cluster.
  8. #18
    Expert johno90's Avatar
    Moranbah QLD
    Correct the light should turn off as soon as the engine is running, my auto uses flash codes through the power hold auto switch. The temp light has never flashed on me.
  9. #19
    Hardcore
    central coast nsw
    was just looking at manual for ya.
    Alarm is wired into speedo metre circute.
    Also mentions A-Trans oil temp light.
    My GTR has an factory alarm similar 105kph.
    believe Japan has 105kph limit.
    just simply removed its earth connection.
    safari is middle eastern? so ask /post the ? for one of the members over there to answer, about alarm!!
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
  10. #20
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    here is a picture of mine. All these lights come on when ignition is turned on but turn off as soon as engine is running. Mine is an auto and you can clearly see the words "A/T OIL TEMP". I have no chime sounding any time. Mine is a 1991 GQ Wagon (Ti model i think)
    Hello from Under Down Under!
