Results 1 to 10 of 16
Thread: Rear Draws for under $50 DIY yr10 shop basics
Threaded View
  1. #5
    Patrol Guru Ade's Avatar
    Apr 2011
    Sabah, North Borneo
    Gday Eli,
    The photos of the roof console. For the front side actually it is bolted together with the clinometer, not to the rear view mirror as I mentioned last night. I used an ally plate painted in black screwed to the console to conceal the opening..
    At the 2nd photo, you can see one of the lock nut that hold flat bar bracket to the existing screw holes for the dorm/roof light. The M6 bolts were tighten up with nut (behind the vinyl) so they become as fixed studs protruding out from the vinyl.
  2. The Following User Says Thank You to Ade For This Useful Post:
    eliurquhart (23rd July 2012)
