Correct. That is why I want it. Car has a remote start function which fumbles on cold mornings. My apologies for using the wrong terminology.
I am here: http://tapatalk.com/map.php?yfbeks
GU4_3"lift_4"exhaust_sliders_Bars_fridge_roof top camper_lockers_duramax_allison_ohh yeah!!!
does the gq one fit
G'day everyone, I'm in search of a standard garrett turbo off a 3ltr GU.
I'm located in Brisbane but willing to pay for postage.
I don't have access to a GQ to see what it looks like. If you can email me a photo? Owen@eastcoastbuildingdesign.com.au
thanks for that, I got it on watch now, he wants a bit much for it ($400) but I will call him after it finishes, I doubt it will go & good luck to him if it does
Mate I have the rear corners, the alloy rear step and the two inner corner brackets off our 99 2.8 GU? The lights still function, however I cut the loom to use the plugs on the steel bar, so a bit of easy rewiring is required. The corners are gold/silver colour
Will these suit your needs?....currently sitting in my shed annoying me, in North Brisbane.
Dave
99 GU 2.8 TD
Brisvegas, QLD
Morton (2nd June 2012)
Morton,
I've got one off my '06 GU IV after fitting a kaymar bar but don't know if it will fit your trol. It's gold, has the inner steel mounting frame, with mounting blots, no lights, in good nick, $200 Brissy.
cheers
The tail lights rear qtr and flares all different. I would not think it will fit.
Dingo55 (21st May 2012)
Thanks for that, but as I JUST put in a new Stainless Steel exhaust last week, I don't think I'm prepared to remove it just yet. But I hear what you're saying, thanks for the advice
Patty, I measured a '03 & '06 GU today both STs. The rear qtr & flares are the same, the distance of the flares & tail lights from the top of the bumper is the same. The bottom of the tail lights on the '03 & '06 start at the same place on each body but the '06 lights extend higher on the rear qtr panel. Only difference is the full plastic bumber covers the center break away U bolt - won't call it a tow or recovery point because it's not. If you fit an '04 or newer plastic bumper on an '03 or earlier, then you would need to fit the extension piece in the centre of the rear subframe, otherwise you won't be able to bolt on that break-away U bolt. Have a look at the attached pdf, page 2 & look for that additional piece - part # 51132. Morton's trol won't have that part. I think it was introduced from '04 onwards.
cheers
