Results 11 to 20 of 29
Thread: Couple of quick Q's about the GQ
    Patrol Guru Ade's Avatar
    Apr 2011
    Sabah, North Borneo
    What about the switch connector at the brake fluid reservoir..?
  2. #12
    Expert GQPorkroll's Avatar
    Hunter Valley NSW
    Yep that will be my first step. I'll go through everything tomorrow thoroughly.
  3. #13
    Feb 2011
    Shed
    45 Post(s)
    Hand brakes mechanical not hydraulic so fluid won't effect it. Will be the switch stuck think you'll need to remove centre console to access
    Tappin N Crappin
  4. The Following User Says Thank You to growler2058 For This Useful Post:
    patch697 (21st May 2012)
  5. #14
    Expert Richo460's Avatar
    Cairns, QLD
    yeah i agree with growlers, there should just be a switch on the handbrake lever, its prob needs adjusting.
    If you going through hell...Keep going
    GQ wagon locked - lifted - 33's, 02 SS ute, XB coupe 460bb, KTM530
  6. #15
    Hunter Valley NSW
    Ok brake problem sorted, I pulled the console and sprayed some contact cleaner on it, and also topped up the master cylinder and the light is now out. It was one of the two. Not sure which one, don't care, but that's one problem down. Thanks for the assistance.
  7. The Following User Says Thank You to GQPorkroll For This Useful Post:
    Bodek G (14th May 2012)
  8. #16
    Quote Originally Posted by GQPorkroll View Post
    good to hear mate, nothing like trying to ignore that annoying warning light lol
  9. #17
    Q2:
    drop boxes will give you more flex than castor plates and if you get the right drop boxes it'll fix your castor swell. everyone i know who went to drop boxes after castor plates... never went back
  10. #18
    Q3:
    I had this problem, even more so in the wet.... it's a GQ factory option. if it's not making noise, i worry :P
    no but really, it's more than likely your body mounts. GQ are know for having them perish. the pain in the ass fix is replace them all.
    http://www.nizzbits.com.au/
    Nizbits is prob the best place to get them as with stuff like the, gen is the way to go
    i did mine with new rubber and bolts.... clunks and groaning went away
  11. #19
    Hunter Valley NSW
    Clunk, they're only brakes, nothing too important! I think it was the contact cleaner as it was only down a frag, but better safe than sorry.
    Yeh I found out it was a body mount Munter, I will order new ones and throw them in. Can't be arsed to do a body lift, I have rock sliders and bars fitted, plus I hate everything going out of alignment.
    In regards to drop boxes, I'll go that way. They look more secure and seem to make more sense.
  12. #20
    How did you find out it was the body mounts. Just visually inspecting them or were they loose cos i'm having the same prob with my car
