Ok, I will explain.
It is a 2000 GU2 wagon (ex zd30) auto with a silvertop td42t motor.
The radiator can't get any cool air because stacked in front are a full width a/c cooler, trans cooler, intercooler and p/s cooler.
I have a tiny little fan on the intercooler, but no room for anything bigger.
It gets very hot at traffic lights and on low range hill climbs.
I recored the radiator, and there is not enough space for a larger radiator, so that won't work.
I replaced the hub and fan with Gu turbo spec Nissan genuine and this has sorted the higher speed stuff but at low revs, does not do enough.
Unless somebody has any suggestions, I think my only option is to see if one of you blokes has a top mount that you want to trade with me. The diesel specialist suggested this, and I tend to agree.
My mate has a factory Gu td42t and his thermo goes off like a frog in a sock at idle, so I am guessing more air is what I need to keep everything cool?
love the auto, but seems to be causing me hassles?
Owen.
