Results 21 to 30 of 38
Thread: Auto confusion
    Patrol Guru Ade's Avatar
    Apr 2011
    Sabah, North Borneo
    Quote Originally Posted by saw13 View Post
    As soon as you turn your key on, does the light come on for two secs then flash 16x ??
    On mine, yes. This still happened, sometimes..
  2. #22
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Yeah i tried this the other day, nd once again just then, light comes on for two seconds then flashes 16x which is suppose to be normal as it does its own sys check, but i still go through the
    diagnosis instructions nd nothing happen lol,
    No, power light comes on for about 2 secs then goes out, that's all that should happen as far as I'm aware.
    When you get a chance, would it be possible 2 record the flashes for me please and post it up???
    Just about 2 send you a pm
    Todd
  3. #23
    Feb 2012
    Rockhampton QLD
    Quote Originally Posted by Ade View Post
    Now I remember one thing!
    1 gears change really quickly (really quickly) unless putting foot down a fair bit, feels a little gutless nd feels like it doesnt grab gears properly,
    3 POWER switch light comes on when turning off O/Drive, visa versa, even when the HOLD switch is active (is that suppose to?)
    This is the first issue that I had with my auto..similar to yours mate. I dont have the hold button though, just the power/od button. So, I just disconnected the TPS (solved the #3) and drove it like a manual (#1)..until I got the 2nd hand unit from a wrecker and its all good. But still..I was like adjusting the TPS more than 7 times to have it change gears at correct speeds. As for the gutless feels and doesn't grab the gear properly, I sorted these issue after the box been rebuild and a Nomad Valve Body from Wholesale Automatic Transmission was fitted.
    The only issue I got left now is the fluid temperature, manageable though. Rodney of W.A.T told me that I should get a hand on a later version of the torque converter as what I have now is an earlier version of tc (F1-smooth bell housing) and it is smaller than the later version of tc (J6-ribbed bell housing).
    I disconnected the TPS, turned the key to the ON pos, O/Drive was turned OFF nd the light comes on, turned ON the O/Drive light goes out, hhmm!!!
    Mine is also a the J6 ribbed box nd also has a GU stall converter as i was told by my mate that i currently bought the motor nd box off.
  4. #24
    Feb 2012
    Rockhampton QLD
    Todd
    Tried the DIA once again Todd, nothing happened,
    But as soon as u turn the key to the ON pos or start the car, the power light comes on solid for 2 secs, then flashes continuosly for 16 times.
  5. #25
    Feb 2012
    Rockhampton QLD
    There is one other option that i can think of before i take it back to the auto leaky, is to disconnect the wiring harness from the auto to the connectors underneath the engine bay nd check for bare or damaged wires, just a thought!!!
  6. #26
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Does the power light flashes indicate an issue - i.e. the number and type of flashes indicates a specific problem .. because mine is having issues as per other threads also, and it flashes about a dozen time when I turn the truck on??
  7. #27
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    In the Haynes manual that I have it's not the,amount of flashes but the length of any given flash, i.e. if third flash stays on longer it is such and such, or if 6 short flashes followed by four long it is means another issue etc....I can't remember the exact wording. Will have a look when I get home. The first time I did the diagnostic check it said I had a problem with my TPS....turns out there was no TPS at all! So it was on the money
    tappin it
    Hello from Under Down Under!
  8. #28
    Aug 2010
    17 Post(s)
    c'mon get the mobile phone recording and post up the flashes for us so we can work out what the fault code is
  9. #29
    Feb 2012
    Rockhampton QLD
    Hey mate sorry ive taken a mobile video of it but it wont let me post it up at all, keeps saying upload failed!!!!
  10. #30
    Feb 2012
    Rockhampton QLD
    tappin it
    Yeah i looked very closely nd every flash is the same exact amount of time lol
