Results 11 to 20 of 31
Thread: Difficulty shifting gears
    22 Post(s)
    are you running the correct gearbox oil, it should be a friction modified oil (VMX 80)
    96 GQ coil/Cab
    08 G6eT
  2. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    thebeatjackson (9th April 2012)
  3. #12
    Feb 2012
    Sep 2011
    adelaide
    18 Post(s)
    G`day mate
    check the hydraulics first. with the engine off bleed the booster by pumping the pedal a few times until the pedal is firm to push to the floor, if it has a small amount of free travel then is firm to push to the floor then the hydraulics are more than likely ok and your problem is the clutch it`s self.
    If it`s the clutch it could be a number of things.
    1 a cracked fork
    2 a cracked diaphragm spring
    3 a broken pressure plate hold back clip there are 3 or 4 of these can`t remember off hand
    4 a broken fulcrum ring
    all of these require box removal
    hope this is of some help
  5. The Following User Says Thank You to pearcey For This Useful Post:
  6. #14
    if the clutch has a soft line, ie rubber hose , check to see that its not bulging under presure too...
  7. The Following User Says Thank You to iansmqshotyy For This Useful Post:
  8. #15
    Expert billyj's Avatar
    gordon
    should be using a gl-4 oil in a patrol gearbox. vmx-80 and vmx-m work well
  9. The Following User Says Thank You to billyj For This Useful Post:
  10. #16
    Feb 2012
    G`day mate
    1 a cracked fork
    Seems to be in the hydraulics from this test, pumped the cluch pedal for about 2-3 minutes with little to no change in firmness.
  11. #17
    Feb 2012
    cheers, I'll change it again, do you use the 80 or the m is there much of a difference between them?
  12. #18
    Sep 2011
    adelaide
    18 Post(s)
    Quote Originally Posted by thebeatjackson View Post
    If there is no fluid leak the mater can be bypassing internally
    Start the engine hold the clutch down with the car in gear for a minute or so and if the car starts to slowly creep away then the master is bypassing
    If it is the master fit a new one don't re kit the old one as the have a special coating on the bore and honing removes this and premature wear becomes a problem
  13. The Following User Says Thank You to pearcey For This Useful Post:
  14. #19
    Feb 2012
    I haven't tried this yet, but I do remember it doing something like this when sitting at traffic lights.
  15. #20
    Sep 2011
    adelaide
    18 Post(s)
    Any dout change the master not that expensive and cheaper than pulling the box.
