Results 1 to 10 of 31
Thread: Difficulty shifting gears
Threaded View
  1. #18
    Sep 2011
    adelaide
    18 Post(s)
    Quote Originally Posted by thebeatjackson View Post
    Seems to be in the hydraulics from this test, pumped the cluch pedal for about 2-3 minutes with little to no change in firmness.
    If there is no fluid leak the mater can be bypassing internally
    Start the engine hold the clutch down with the car in gear for a minute or so and if the car starts to slowly creep away then the master is bypassing
    If it is the master fit a new one don't re kit the old one as the have a special coating on the bore and honing removes this and premature wear becomes a problem
  2. The Following User Says Thank You to pearcey For This Useful Post:
    thebeatjackson (9th April 2012)
