Results 1 to 10 of 12
Thread: turbo timer
    Jun 2011
    Darwin NT
    turbo timer
    Hi guys,
    looking for a DIY for turbo timer fitting, im pretty sure they come with instructions but after some advice from the forum gods.
    Aug 2011
    Timbo - there are a few on the market, ARB sell them at a fairly hefty price they are rebadged, can't remember the name. I've been considering a Jayca DIY kit, comes as a circuit, needs soldering and installation.
  3. The Following User Says Thank You to maphew For This Useful Post:
    Timmo (29th January 2012)
    Expert the godfather's Avatar
    Mar 2011
    Piara Waters, WA
    Hi Timbo, Redarc do a fairly simple one to install. Still needs some skill though. Ex Coventrys I think.
    Good luck.
  5. The Following User Says Thank You to the godfather For This Useful Post:
    Advanced BundyDave's Avatar
    Mar 2011
    Bundaberg
    Bogaard fitted one to my 06 GU easy install.
    Gert B Frobe
    Guest
    I went the Jaycar kit as I was doing an electrical course and cost all of $22. Works fine and installs easily to your ignition power supply even comes with its own relay. Took me a little bit to work out the instructions but all of about 2 hours in soldering and about an hour or so tapping into the power supply. Just remember to put the thermo unit on the opposite side of the engine bay to the turbo.
  8. The Following User Says Thank You to Gert B Frobe For This Useful Post:
  9. #6
    Patrol God nowoolies's Avatar
    Perth
    g`day Tim
    have a look at the one`s in Oppisite Lock
    HELL NO !!!!!!
  10. The Following User Says Thank You to nowoolies For This Useful Post:
  11. #7
    Advanced BEP120's Avatar
    Central Coast NSW
    I put an ARB one on my GU. Very easy came with instructions and is a plug and play. The only wire I had to connect is a grounding wire everything else just plugs into the ignition plug.
    The ARB is a Boggard just with a ARB badge on it.
    2003 GU ST-L, ZD30TD, 2 inch lift, 2.5m side awning, cargo rack, snorkel, 285/75/16 M/T tires, cargo draws, cargo barrier, UHF, DVD/CD player, on board air compressor, duel batteries, B/Bar, spot lights, 50ltr water tank, Pillar pod with egt & boost gauges, catch can, egr block, dawes and needle valves, 3" exhaust.
  12. #8
    Perth northern suburbs
    Quote Originally Posted by BEP120 View Post
    how much did you pay for this unit please mate and how long did it take you to install
  13. #9
    Central Coast NSW
    Quote Originally Posted by buenno View Post
    Hi buenno, Just found the receipt. I paid $209 back in Nov 2009. It took me about an hour and a half. Very easy job you just need to take the bottom cover off the steering wheel surround and the ignition plug is under there. Plug it in and mount the main unit up under the dash run the earth wire to a screw on the body and the timer unit somewhere accessible. I didn't have to cut or extend any wiring.
  14. The Following 2 Users Say Thank You to BEP120 For This Useful Post:
    buenno (30th March 2012), Shonky (2nd August 2012)
  15. #10
    Patrol Freak Wine_maker's Avatar
    Nov 2011
    Kazakhstan, Almaty.
    8 Post(s)
    I install car alarm with turbo timer function. The alarm system will be good addition to your turbo timer lol
    I'm Alexander and I'm the happiest owner of GQ Nissan Safari in the whole Central Asia
