I put an ARB one on my GU. Very easy came with instructions and is a plug and play. The only wire I had to connect is a grounding wire everything else just plugs into the ignition plug.
The ARB is a Boggard just with a ARB badge on it.
2003 GU ST-L, ZD30TD, 2 inch lift, 2.5m side awning, cargo rack, snorkel, 285/75/16 M/T tires, cargo draws, cargo barrier, UHF, DVD/CD player, on board air compressor, duel batteries, B/Bar, spot lights, 50ltr water tank, Pillar pod with egt & boost gauges, catch can, egr block, dawes and needle valves, 3" exhaust.
