Page 6 of 33 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 329
Thread: Taslucas's TB42 Ti
  1. #51
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Try disconnecting the battery for a few hours and let the ECU reset itself. Then see if you get the errors again as sometimes the fault happens but the ECU doesn't clear itself ...
    At least try that first before hunting for something that may not be an ongoing problem ...
  2. #52
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Quote Originally Posted by Bigrig View Post
    Cheers, will do that overnight
    Lucas
    Hello from Under Down Under!
  3. #53
    Oct 2010
    Lucas
    Give it a go mate - mine did the same thing a while back (on another thread in here) and resetting the ECU resolved it - some error codes need to have the ECU reset via the consult unit, but most will clear after a couple of hours disconnected (I left mine overnight just to be sure also as no one could put a finger on just how many hours was needed).
  4. #54
    Aug 2011
    North West Tas
    56 Post(s)
    Awesome, I will give it a try....so is it just to clear the code or would it fix a malfunction in the ecu (or whatever is causing the lockup converter to play up again?)
    Lucas
  5. #55
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Lucas
    Lucas
    From my understanding it will clear the error code, but won't fix a malfunction in the ECU or whatever the problem is, and from what I have been told even if there is an error code still in the system form a previous problem that has since been fixed it will not cause any problems.
    But I hope you can prove me wrong and clearing the error code solves your problem.
    Todd
  6. #56
    Oct 2010
    Lucas
    Todd
    Correct, but if a malfunction it'll error out again and isolate it hopefully. I had three error codes that all cleared and never reappeared for some reason.
    If they reappear, hopefully it's not all of them, and so begins the hunt for the 'real' problem.
  7. #57
    Aug 2011
    North West Tas
    56 Post(s)
    Ahhh well I think it's just doing what it's ment to then and picking up the fault that I can feel when im driving!
    But I'll disconnect the battery tonight and see what happens
    Thanks,
    Lucas
  8. #58
    Aug 2010
    17 Post(s)
    Thanks,
    Lucas
    Let us know what happens, If it doesn't clear, gives us a starting point, unfortunately error codes only narrow the problem down, say for example your error read: inhibitor switch, power shift switch, kickdown switch or idle switch circuit is disconnected or the control unit is damaged.
    It could be none of those that at fault, but the problem you have is caused by another problem that is causing a problem with one of those....
    .............hope that made sense Lucas............had a few beers
  9. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
    taslucas (29th February 2012)
  10. #59
    Aug 2011
    North West Tas
    56 Post(s)
    yep, made perfect sense mate but ive had a few turkeys too.....think im speaking your language lol.
    i reckon the problem is the temp sensor. Its doing the same thing as last time and was only replaced by a second hand one. Although its just a bit too much of a coincidence to have failed again.
    back to the drawing board
    Grrrrrrrrrrrrrrr...........!
  11. #60
    Aug 2010
    17 Post(s)
    Don't think I have said it yet, so if I haven't........big congrats on reaching the 1000 posts mark....... ( 99 posts ago ) *L*
    Well done mate, keep em coming, just not with posts of probs with the auto!!!!!!!!
  12. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
