Results 1 to 10 of 31
Thread: rd28 to td42 conversion gq
Threaded View
  1. #4
    There are 6 threaded holes on the drivers side of the engine block, if you make a suitable thickness steel plate that covers all 6 holes you can bolt your engine mount to the plate where it needs to be - easier than relocating the mount on the chassis. Additionally to that, if you put in a bit more planning to that steel plate and extend it down a bit further to beside the sump, you can mount a second A/C compressor to it to use as an air compressor. Check this thread for more info and photo's of the compressor mount idea; http://www.nissanpatrol.com.au/forum...air-compressor
    Tony
  2. The Following User Says Thank You to YNOT For This Useful Post:
    HammerBuilder (8th May 2012)
