Page 108 of 212 FirstFirst ... 106107108109110 ... LastLast
Results 1,071 to 1,080 of 2116
Thread: Merged - Deleted "Wanted"
  1. #1071
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Quote Originally Posted by pro.020 View Post
    Hi guys, I'm looking to buy a full roof cage or individual rhino racks for my GQ to mount my roof tent on. Preferably before tue, wed. You can PM me with details.
    Thanks.
    Good luck with the search mate, bit of a tough ask but you never know.
    Might pay to check out ebay to see if there is some around the area you can pick up from as well...Good luck mate
    ________________________
    ______ 2017 D-Max _______
  2. The Following User Says Thank You to Maxhead For This Useful Post:
    pro.020 (22nd December 2011)
  3. #1072
    There's a few Alloy ones on Ebay ATM but they are SWB so hopefully you get it sorted for the Christmas break.
  4. The Following User Says Thank You to AB For This Useful Post:
  5. #1073
    and don't forget to have a look in Gumtree as well, I've seen a few knocking around in there from time to time
  6. The Following User Says Thank You to Clunk For This Useful Post:
  7. #1074
    Heres my VN Airbox Upper and Lower installed into my 1988 GQ.
    They used to be around $40 for both Upper and Lower.
    http://imageshack.us/photo/my-images...dpatrollpg.jpg
  8. The Following User Says Thank You to gq4200 For This Useful Post:
    ozzyboy (22nd December 2011)
  9. #1075
    Another one
    http://imageshack.us/photo/my-images...atrollpg2.jpg/
    At this stage the car was running straight LPG through an EFI intake manifold with the injector holes plugged.
    Up to VS I think are the same except VS has a sensor hole in the upper which will need to be plugged if you dont have the sensor filling the hole.
  10. #1076
    I later installed the factory GQ airflow meter in one of these by enlarging the inlet hole and drilling new mounting holes. Luckily there is enough area to allow you to do this as the Factory Airflow meter is quite a bit larger.
    Also worthy of note is the filter element is identical to the Factory GQ patrol EFI one.
  11. #1077
    I later installed the factory GQ airflow meter in one of these by enlarging the inlet hole and drilling new mounting holes. Luckily there is enough area to allow you to do this as the Factory Airflow meter Mounting is quite a bit larger.
    The only Downside I found that it would have been more difficult to attach a Snorkel to this setup.
  12. The Following User Says Thank You to gq4200 For This Useful Post:
  13. #1078
    Expert ozzyboy's Avatar
    Oct 2011
    springwood, qld
    any chance, in that location, to get around the overflow bottle to snorkel cut out?
    I think we are onto a winner here . cheers
    ozz
  14. #1079
    Beginner pro.020's Avatar
    Oct 2010
    BIRKDALE
    Thanks guys. Gumtree didn't even cross my mind.
  15. #1080
    hope you find something mate, you may be lucky
