Page 131 of 188 FirstFirst ... 129130131132133 ... LastLast
Results 1,301 to 1,310 of 1871
Thread: The "Tank" - Big, Grey and Ugly ..
  1. #1301
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Quote Originally Posted by patch697 View Post
    Not good Bigus....... I'll read more as you post it but for now go get some shut eye brother.
    Thanks fella - still going!! Getting delirious now as I've hoovered half a bottle of scotch straight so far!! lmao. I'll discuss it with you as I know you are across these sorts of things, but truly down heartened by the process ... has not lived up to the hype one bit ...
    AGAIN!! I'll disclaim ... Maybe not setup right. But installed as per the documents in the box, and to be honest, can't really go wrong - remove bolts and harnesses, replace valve body and install bolts and harnesses ...
    That said, I'll call Rodney tomorrow from Wholesale Automatics to discuss, but would need to be significant change to impress me ...
    Damn it. Don't like throwing away my hard earned quite frankly!
  2. #1302
    Oct 2010
    Quote Originally Posted by growlers71gq View Post
    Ouch!!!!!!
    Indeed fella ... very OUCH!!!!!
  3. #1303
    Oct 2010
    Quote Originally Posted by clunk71 View Post
    hmmmm not good Biggus
    Thanks mate and too true ... they absolutely reassured me THIS was the problem, and to be honest, it probably solves 99% of problems, but mine is a bucket of sh!t ... $1000 to end up with the same problems as detailed before the swap - and no chance of getting my money back (I'm not that naive).
    Seriously p!ssed ...
  4. #1304
    Quote Originally Posted by Bigrig View Post
    and not because of the bottle og scotch hey!!!!............ sorry mate, here's to hoping that it has something to do with the installation mate........ and no I'm not dissing your work, just also hate seeing the hard earned go to waste
  5. #1305
    591 Post(s)
    I work on the same street as these guys mate so just yell out if you need me to do anything.
  6. #1306
    Patrol Guru Airstrike's Avatar
    Feb 2011
    That sucks dude. What about water injected head like mine?
    water injection, also known as anti-detonant injection, is spraying water into the cylinder or incoming fuel-air mixture to cool the combustion chambers of the engine, allowing for greater compression ratios and largely eliminating the problem of engine knocking (detonation). This effectively increases the octane rating of the fuel, meaning that performance gains can be obtained when used in conjunction with a supercharger, turbocharger, altered spark ignition timing, and other modifications. Increasing the octane rating allows for a higher compression ratio which increases the power output and efficiency of the engine. Depending on the engine, improvements in power and fuel efficiency can also be obtained solely by injecting water. Water injection may also be used to reduce NOx or carbon monoxide emissions
  7. #1307
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Sonunds like Scotty needs 2 come 2 my place for a drinkieeeeeeeeeeeeeeeee.
    That's s!cks mate. I'll see my old man 2morrow and ask him about his, I think he went stage 2 valve body from wholesale, and hasn't had any drama's
    You weren't drinking while putting the new one in where you??????????? *LMAO*
  8. #1308
    Oct 2010
    No disrespect taken at all champion - I agree with you, hope it's something simple - don't mind pulling it off again, but it's sort of a pretty straight forward swap over?
  9. #1309
    Oct 2010
    Thanks boss - as said, I'll chat with Rodney tomorrow and see how I go ... Put in a Crane Cams high performance coil at the same time, but can't see how that would have anything to do with the torque converter issue - the old coil died, new coil in?? Am I missing something?? Does it affect the TPS and/or TCU and I've stuffed up/not adjusted something?
  10. #1310
    Oct 2010
    Quote Originally Posted by Ryan View Post
    Looked at water/methanol injection when we intercooled it - not sure that would sort the gearbox problem though boss ... probably exacerbate it!!
