Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: air condition pump converted to air compressor?
    Oct 2011
    my friend said to me the other day that he heard you can turn your ac pump into an air compressor just wondering how this can be done if at all
    Hi mate,
    There is a HEAP of info on the net about this, your "Air Conditioning Pump" is actually your "Air Conditioning Compressor" all you are doing is changing its use. You need to be mindful of the lubrication of it but search google and you will find
    Google Search "Converting to Endless Air"
    I have not even searched here but there may be something on this forum even, but there is a heap of stuff.
    Good luck
    Check here for a step by step guide with clear photo's; http://www.grungle.com/endlessair.html
    Tony
    Oct 2011
    culverden nz
    just had a quick look at this and it looks very interesting will have to have a good read of it later thanks guys
  5. #5
    Patrol Guru Ade's Avatar
    Apr 2011
    Sabah, North Borneo
    Gday mate,
    I,ve used Sanden A/C compressor as my onboard endless air set up. Its a great thing to have if you're going to use lots of air on your troll like air tools or air suspensions. A bit tricky to mount the compressor though, you'll need to fabricate the mounting bracket(s). Mines mounted under the steering pump. But might not need this set up as I wont be using lots of air on my troll. Plus my ARB air compressor for the locker will serve me good enough to just airing tires..try to keep the troll as basic as possible. But its your call mate. Good thing to have onboard still..
    Ade
  6. #6
    Quote Originally Posted by Ade View Post
    Gday mate,
    Ade
    Hey Ade,
    Have you got any pics of you mounting? I have been keen to fit up one to the power steering, do you have any drawings of your brackets.
    I'd be keen as for some Info on how you did it mate. Looking to sort this out over summer.
  7. #7
    Apr 2011
    Sabah, North Borneo
    I made 2 identical brackets that bolts on to the fuel pump gear cover and at the back of it..but I'm sorry mate, I didn't have any drawings of it. I'll see what I can do for you. I'll try to post some better pics when I got home later. This is the pic from my computer in the office.
  8. #8
    Apr 2011
    Sabah, North Borneo
    By the way mate..its a Sanden 507 compressor.
  9. #9
    Hey Ade,
    Check out this link (http://www.grungle.com/endlessair.html), it has drawings of the brackets at the bottom of the page.
    Tony
  10. The Following User Says Thank You to YNOT For This Useful Post:
    MudRunnerTD (3rd November 2011)
  11. #10
    Apr 2011
    Sabah, North Borneo
    This is the best picture mate. I mounted mine when the engine was off the troll, so its pretty easy job. Plus by using Sanden 507 compressor, I had to trim off just a little portion of the panhard mounting bracket on the chassis otherwise it wont fit. So you might have to consider smaller compressor, it will leave you ample space to work on it and laying out the air line etc.
  12. The Following 2 Users Say Thank You to Ade For This Useful Post:
    MudRunnerTD (3rd November 2011), YNOT (2nd November 2011)
