Results 1 to 9 of 9
Thread: 1988 GQ Stabliser
    Advanced jdavy5's Avatar
    Aug 2011
    1988 GQ Stabliser
    Recently got a GQ patrol and im wondering what the stabliser lever does located near the steering wheel.
    Patrol God Bob's Avatar
    Oct 2010
    Pakenham
    47 Post(s)
    That releases the Stabaliser(Sway Bar) in the rear of the Patrol to allow for more Flex(Wheel Travel) when Off Road.
    Would not advise Driving on normal Roads with this released
  3. The Following User Says Thank You to Bob For This Useful Post:
    jdavy5 (4th September 2011)
    Sep 2011
    Khulna,Bangladesh
    Bro is there any problem if the lever released while running?if I use it on bumpy on road?
    Sway bars are used to reduce body roll and increase stabillity on road, especially important as speed rises. The downside is swaybars also reduce axle articulation off road which is why Nissan fitted the swaybar disconnect. Disconnecting it on bumpy roads has no real benefit, use it for serious 4WDing.
    Tony
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    my sway bars got taken out when I lifted it and it still hasn't gone back in even though it back 2 pretty much standard, I personally didn't find it made a huge difference having it in there or not.
    Sep 2011
    Khulna,Bangladesh
    Is it call '5 link rigrid axle coil spring' which are found on high spec safaris like granroad?
    Quote Originally Posted by Arman View Post
    Not 100% sure.
    Tony
    Sep 2011
    spewin mine has not got that
  10. #9
    Feb 2011
    Shed
    45 Post(s)
    Quote Originally Posted by flex82 View Post
    Gday flex you can get manual disconnects for your trolls swaybars mate,
