Page 164 of 220 FirstFirst ... 162163164165166 ... LastLast
Results 1,631 to 1,640 of 2192
Thread: AB's new GQ is finally here
  1. #1631
    I had some pretty obvious mods on mine when I did this too like the turbo etc and he didn't even notice anything. It was raining and cold and he just wanted to check the number and go inside...
  2. #1632
    Yeah it's been on my mind Plassy. From what I understand a like for like engine just needs to be taken into the pits purely for someone to visually check out the engine number.
    I had to do that when they stuffed up my engine numbers and he did was check my number, nothing else.
    Now....is a td42ti 04 model a like for like engine?
    Yes it is like for like.
  3. The Following User Says Thank You to Winnie For This Useful Post:
    AB (21st October 2016)
  4. #1633
    Can confirm from when I did mine in the oyta.
    Like for like.
    They just wanted to sight the numbers.
  5. The Following User Says Thank You to jay see For This Useful Post:
  6. #1634
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    Yep simple engine number check is all it should be. The chick that checked my rd28ti -> td42t conversion didn't even know where to start looking I had to show her.
  7. #1635
    Yep me too, she only saw about half the numbers and said "yeah that's fine"
  8. #1636
    476 Post(s)
    Haha yeah same here. Even on the second check, after i got the engineers report they had to check again, didnt even look at the air box and intercooler which are now a no no.
  9. #1637
    Vic roads don't care as long as the paperwork is correct it makes their job easy.
  10. The Following User Says Thank You to jay see For This Useful Post:
    rusty_nail (24th October 2016)
  11. #1638
    Had a successful day! Alternator, turbo, thermostat housing, exhaust manifold and oil cooler installed.
    Water drain and oil drain done. Need to go to pirtek to extend oil feed for alternator as the original bung is stripped but I can tap into the one 100mm away.
    Unfortunately the position of oem oil drain is in the way of my original water feed for turbo so need to shorten hose.
    Worked out oil feed for turbo on the correct side as the td42t has a dedicated port...hooray!
    The day's cut short with the old ladies birthday and some missing gaskets but there's good progress!
  12. The Following 11 Users Say Thank You to AB For This Useful Post:
    BigRAWesty (22nd October 2016), growler2058 (22nd October 2016), gubigfish (22nd October 2016), jay see (23rd October 2016), Kimbo63 (22nd October 2016), mudski (22nd October 2016), Plasnart (22nd October 2016), Rossco (22nd October 2016), Touses (22nd October 2016), Winnie (22nd October 2016), Woof (22nd October 2016)
  13. #1639
    Patrol Guru Sprock's Avatar
    Jun 2015
    Heyfield Vic
    35 Post(s)
    Good to hear it's moving along nicely mate 👍🏼
  14. #1640
    Yep definitely a productive day, nice work! Just another step closer
  15. The Following User Says Thank You to Winnie For This Useful Post:
    MB (23rd October 2016)
