Page 163 of 220 FirstFirst ... 161162163164165 ... LastLast
Results 1,621 to 1,630 of 2192
Thread: AB's new GQ is finally here
  1. #1621
    Boss has gone to WA so I snuck out and purchased some more bits for the build.
    I also realised the power steering brackets are different so my GQ bracket won't fit.
    Little surprises are cropping up but no biggy.
    So far the differences that effect my bolt ons are...
    Vac pump
    Power steering bracket
    Flywheel
    Some ports on the block not needed
    Dipstick length
    Haven't checked alternator mounts yet but should be ok.
    Clutch to flywheel fits thank god! I heard some only have 2 holes for the 4 x locators on flywheel but all good for me.
    Oil feed for turbo
    Oil drain might need adjusting
    So far these are fine and should all be bolted up on the weekend...
    Engine mounts
    Inlet manifold
    Exhaust manifold
    Water pump
    oil cooler
    Rocker cover
    Alternator and mounts I hope
    Air Con
    Pulleys
    Injector pump, surely the fuel lines would be the same?
    Glow plugs,
    Injectors, glow rail, etc
    Sandwich plate
    Need to get the old spigot bush out, haven't got a puller so going to try the old grease and clutch tool trick!
    Can't think of anything else?
    Bit of a list for myself
    Need Power steering bracket
    Need tacho sensor spacer
    Need injector number 3 fixed and all new washers for them
    Vac pump cover plate
    New oil, coolant, etc.
  2. The Following 3 Users Say Thank You to AB For This Useful Post:
    macca (19th October 2016), Rossco (19th October 2016), Woof (19th October 2016)
  3. #1622
    SUCH IS LIFE Maxhead's Avatar
    ACT
    More importantly Andy, when's the piss up? Ohhh I mean the pizza night...lol
    ________________________
    ______ 2017 D-Max _______
  4. The Following 4 Users Say Thank You to Maxhead For This Useful Post:
    AB (19th October 2016), macca (19th October 2016), Stropp (19th October 2016), Woof (19th October 2016)
  5. #1623
    Patrol God Stropp's Avatar
    38 Post(s)
    yes i have planning to do, only because i like pizza
  6. The Following 2 Users Say Thank You to Stropp For This Useful Post:
    Maxhead (19th October 2016), Winnie (19th October 2016)
  7. #1624
    Make it sooner rather than later mate, we don't want Amy to pop at your house!
  8. The Following 2 Users Say Thank You to Winnie For This Useful Post:
    BigRAWesty (20th October 2016), Stropp (20th October 2016)
  9. #1625
    Just so time poor during the week mate.
  10. #1626
    Oct 2010
    Old Bar, NSW
    The pizza up is more important than the build, should've known that!
    Macca
  11. The Following 4 Users Say Thank You to macca For This Useful Post:
    jack (19th October 2016), Rossco (19th October 2016), Stropp (20th October 2016), Woof (19th October 2016)
  12. #1627
    Yeah just chuck that 2F in the bloody thing and let's partay . .
  13. The Following 2 Users Say Thank You to Rossco For This Useful Post:
    BigRAWesty (20th October 2016), Winnie (19th October 2016)
  14. #1628
    Everything is prept ready for all the bolt ons tomorrow!
    Have spent all week collecting everything I need and cleaning up bolt ons from my old engine except for a few custom things I need to make but let the fun begin!
  15. The Following 9 Users Say Thank You to AB For This Useful Post:
    BigRAWesty (22nd October 2016), Clunk (24th October 2016), gubigfish (22nd October 2016), jay see (21st October 2016), Rossco (21st October 2016), Sherro (21st October 2016), Stropp (21st October 2016), TPC (21st October 2016), Woof (21st October 2016)
  16. #1629
    Just thinking aloud here mate......my understanding of putting new donks in is that you need to inform VicRoads so they can update the rego details. Does it need to go over the pits? If it does, are there any implications with mods to the original specifications of the TD42T? Does it need to be original spec for their inspection?
    Yeah it's been on my mind Plassy. From what I understand a like for like engine just needs to be taken into the pits purely for someone to visually check out the engine number.
    I had to do that when they stuffed up my engine numbers and he did was check my number, nothing else.
    Now....is a td42ti 04 model a like for like engine?
  17. The Following 2 Users Say Thank You to AB For This Useful Post:
    Plasnart (21st October 2016), Stropp (21st October 2016)
  18. #1630
    38 Post(s)
    yep for sure
  19. The Following 2 Users Say Thank You to Stropp For This Useful Post:
    AB (21st October 2016), rusty_nail (24th October 2016)
