Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: AC Bearing
    Oct 2015
    Aldinga Beach SA
    AC Bearing
    Gidday, After a very wet & muddy trip to Birdsville, the mechanic has said the AC bearing is buggered in the GU 07. Has said it will be around $900 to replace as he can't find the replacement bearing kit.
    Any ideas where we can get them from or is it best to replace the compressor?
    SOLD !!!!! White 2010 GU DX, bull bar, rear drawers, reversing camera, factory snorkel, pioneer roof rack, scangauge, dual battery, awning ....
    477 Post(s)
    If its the idler bearing this can be changed no worries. Idler bearing is common to get full of crud on these. I would be seeing if its this before forking out $$$ on a new compressor. Unless your mechanic is 100% its not the idler bearing. If its the bearing inside the compressor itself. Yeah then a new compressor is in order.
  3. The Following User Says Thank You to mudski For This Useful Post:
    Roosim (12th September 2016)
    Oct 2015
    Aldinga Beach SA
    Thanks mate. Yep he is sure it's in the compressor. There goes more $ !
    The a/c bearing can be replaced.
    I did mine about a year ago. Plenty of info on the web on how to change, not too hard of a job.
    Best is to take off the belt and spin the a/c by hand, if noisy thats your problem.
    Bearing cost about $30 from memory.
    Any good bearing supplier should stock them. I went in with the old one and they matched it up.
    I think I still have the part # somewhere.
    Sent from my XT1068 using Tapatalk
  6. The Following 3 Users Say Thank You to jay see For This Useful Post:
    OuchOne (20th May 2022), Roosim (13th September 2016), threedogs (16th September 2016)
    If you want to give it a Crack I have a brand new bearing here I was going to use, but my compressor clutch has seized onto the shaft so it's a Warrenty job.
    You can have it for cost price if ya like.
  8. The Following User Says Thank You to BigRAWesty For This Useful Post:
  9. #6
    Patrol God Stropp's Avatar
    38 Post(s)
    Yes I've had mine done by an auto sparky
  10. The Following User Says Thank You to Stropp For This Useful Post:
  11. #7
    477 Post(s)
    You did the idler bearing though didn't you John? Not the actual bearing inside the compressor. As to do this the system needs to be degassed and the compressor disassembled. Disregard this if you did the bearing inside the compressor.
  12. The Following User Says Thank You to mudski For This Useful Post:
  13. #8
    Patrol Guru Kimbo63's Avatar
    Dec 2015
    Perth WA
    5 Post(s)
    I think he is talking off the bearing on the compressor clutch not the internal compressor bearings if they fail it all over for the hole aircond system will need a pull down and flush
  14. The Following 5 Users Say Thank You to Kimbo63 For This Useful Post:
    BigRAWesty (13th September 2016), jay see (13th September 2016), mudski (13th September 2016), Roosim (13th September 2016), threedogs (16th September 2016)
  15. #9
    Yeah, the one that's behind the clutch. With the belt off you can tell if that bearing is shot or not.
  16. The Following 3 Users Say Thank You to jay see For This Useful Post:
    dom14 (15th September 2016), mudski (13th September 2016), Roosim (13th September 2016)
  17. #10
    Oct 2015
    Aldinga Beach SA
    Thanks for all the info, most appreciated. It is the internal compressor bearings - booked in with the mechanic on Friday.
    Thanks Westy - will get back to you once we know.
  18. The Following User Says Thank You to Roosim For This Useful Post:
