Page 664 of 1057 FirstFirst ... 662663664665666 ... LastLast
Results 6,631 to 6,640 of 10566
  1. #6631
    177 Post(s)
    Rolled out all the winch rope to dry it out and have a look. Inspected all the winch connections, etc...
    Dried out all the awning from the wet camping weekend before. Found out one of the horizontal poles isn't sticking when twisted. Maybe wet? Don't know.
    Can or will???
    I have thought about a re map..
    Save forking out for vales and a chip..
    Just map it..
    Im very happy with performance from a DP chip [5]
    and dawes and needle valve. getting 15 towing [hwy]
    and 12 around town and full 3" system.
    I wouldnt go the CC intercooler on the ZD30 as I just dont think the gains per $$$$ are there.
    My EGTs are great just using a diesel smart tigged intercooler, but you will need a new IC
    BigRAWesty (14th June 2016)
  4. #6633
    Fitted this water temp sender adaptor.
    Only needed to cut 25mm out of the top hose.
    Also used a 12mm to 4mm terminal cover to
    neaten it up a bit as well
  5. The Following User Says Thank You to threedogs For This Useful Post:
  6. #6634
    477 Post(s)
    Im confused John. What was wrong with the one you drilled into the thermostat housing?
    jay see (17th June 2016)
  8. #6635
    Have the same issue with one of mine, doesn't stick where it needs to but does in other parts of the tube. I'm thinking that the inside diameter of the tube has increased slightly, so not sure hoe to fix it
  9. The Following User Says Thank You to Clunk For This Useful Post:
    Hodge (14th June 2016)
  10. #6636
    177 Post(s)
    I have that issue with the other tubes. Annoying! But this bastard today won't lock anywhere. ..
    Can you ruffen up the gnarly bit
  12. #6638
    177 Post(s)
    I'll give it a shot . Might still be very wet on the inside. Hence not griping. Awning endured a ton of rain 2 weekends ago.
    I know I can just walk in and get replacement poles no question asked anyway so not really bothered too much just annoying.
    477 Post(s)
    I reckon its just wet inside the pole. Mine did the same. Either that or when you tighten it up you do it too tight and its stretched the inside of the pole just enough for it not to catch.
  14. #6640
    Patrol God Stropp's Avatar
    38 Post(s)
    i had that problem and all i did was rough up that nut on the end of the pole shown with the pattern on it with a bit of rough sandpaper.
