Page 663 of 1057 FirstFirst ... 661662663664665 ... LastLast
Results 6,621 to 6,630 of 10565
  1. #6621
    Why? Your only going to benefit from it.
    It's just more stuff...
    And as you know now, tis illegal..
    Might use black tube. Bit less obvious..
    Ecu remap.....
  3. The Following User Says Thank You to nissannewby For This Useful Post:
    BigRAWesty (13th June 2016)
  4. #6623
    Ecu remap.....
    Will that assist the over boost though?
    Thought re maps were aimed at increasing boost and fuel figures..
    Yes it can...
  6. #6625
    Yes it can...
    Can or will???
    I have thought about a re map..
    Save forking out for vales and a chip..
    Just map it..
    Can or will???
    Just map it..
    It can and will with the right tuner doing it. EGR can also be deleted.
  8. The Following User Says Thank You to nissannewby For This Useful Post:
  9. #6627
    Yea have read that too..
    Shut it off for good..
    So....
    Who to see.. and $$$$$
    177 Post(s)
    To be honest. I think your pissing against the wind mate. Get rid of the Ecu boost control and enjoy the fun times with controlled boost.
    I'm not eliminating the option. Just prefer not to do it if needed..
    Probably the best thing I've ever done to my 3L. Getting rid of the stupid ECU yoyo boost and making it all nice and linear with the needle and dawes (and eventually) a wastegate setup, made the best difference to the cars drive-ability among all the other mods.
    When I done the needle/dawes, I was kicking my self for not doing it earlier.
  11. The Following User Says Thank You to Hodge For This Useful Post:
  12. #6629
    177 Post(s)
    Just changed oil and filters. I was about 2500km over, but all is good now. Had a bit of a hassle with right size sump washer (again), but got int in the end.
  13. The Following 2 Users Say Thank You to Hodge For This Useful Post:
    nissannewby (13th June 2016), Touses (13th June 2016)
  14. #6630
    Patrol Guru Chubba's Avatar
    Oct 2013
    Adelaide
    5 Post(s)
    Rotated and balanced the MaxTreks.
    98' Ti, 4.5L, 2" lift, factory rear diff lock with front E-locker, 63% reduction gears
    "GO YOU CROWS"
