Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: TD42 water pumps... what would you be prepared to pay
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    Any cavitation issues related to water pumps will be more due to high revving hot engines combined with poor coolant quality rather than water pump impeller gap.
    Reducing the gap will increase the flow but then you need to be sure that the other components in the system can handle that. Also be wary of pumping coolant too quickly through the radiator..
    I'm new to TD42 engines but I've done a fair bit of research since I started my conversion and I haven't come across any other mention of these engines having cavitation issues with standard water pumps.
    This is why I found BA's original premise interesting.
    As Cuppa mentioned, these TD42s have more of a reputation for solidity and longevity.
    Here's a pic of the original water pump I removed from my engine. Not the slightest sign of cavitation erosion.
    John
  2. The Following User Says Thank You to jff45 For This Useful Post:
    Bloodyaussie (6th August 2015)
  3. #22
    John is right. Cavitation will usually only occur at sustained high rpm. Cavitation is usually a supply issue so there is not enough water available to be pumped.
    Machining will help to increase flow but is not enough of an increase to cause problems. It is still within the control of your thermostat and cap.
    You dont have to machine it. You can just replace it with a new one.
  4. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
    Bloodyaussie (6th August 2015), Robo (7th August 2015)
  5. #23
    Thomastown, Melbourne
    6 Post(s)
    Thank you guys this is good stuff... in the end I have stayed with the stock pump but have just finished replacing the radiator.
    Its a subject I had not heard of until a few weeks ago and the discussions varied... cheers for all the input.
  6. #24
    Some really good advice in this thread gents on this subject from knowledgable members, well done!
    There are bucket loads of wrong information about this on Facebook!
  7. The Following 3 Users Say Thank You to AB For This Useful Post:
    Hodge (6th August 2015), MudRunnerTD (6th August 2015), Winnie (6th August 2015)
  8. #25
    Thats why I don't use FB. I use NP Book.
    Will be interesting to see what temps I will see when I'm up and running.
  9. The Following 2 Users Say Thank You to mudski For This Useful Post:
    AB (6th August 2015), Hodge (6th August 2015)
  10. #26
    Hardcore
    central coast nsw
    Going by the pic of impeller I'd hazzard a guess of some cavitation present given the partial & uneven cleanliness of the impeller.
    wouldn't a even flow of coolant produce even deposits?.
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
  11. #27
    Hardcore
    central coast nsw
    I used to own a boat and my take on cav is its also linked to power supply ( linked to rev's as pointed out by nissannewby )overtaking the ability of pitch of blade to grip the water.
    gap and impeller design has heaps to do with cavitation.
    nismo gtr performance pump ver's std pump,std & N1pump.jpg have larger blade but 1 less and a backing plate on impeller to take care of clearance on other side of pump case.
    ie same as this post discussing decking to reduce turbulence on block side if pump.
    so any improvement you can do should help.
  12. #28
    Morayfield, QLD
    I think the uneven deposits are because these Jap import engines sit around for a long time.
    I gave it a quick clean with a small brass brush and the muck just fell off it.
    Trust me there's not the slightest sign of erosion.
    John
  13. #29
    Morayfield, QLD
    Also thought this might be of interest. I found this image in a thread where a guy was changing his water pump. He actually bolted a new pump onto this and is quite happy with the outcome so let's not get too worried with what we have..
    John
  14. The Following User Says Thank You to jff45 For This Useful Post:
    mudski (7th August 2015)
