Results 1 to 6 of 6
Thread: GQ Front Wheel Bearings
    Apr 2011
    Broken Hill - Merbein - Pooncarie
    Howdy I have about 5-10mm Wobble on drivers side front when jacked up (Wheel Bearings?)
    Simpson Desert GUtsy ute's Avatar
    Apr 2011
    Forestdale Brisbane
    Could be hub pivot bearings also.
    With the wheel jacked up, watch the hub while you wobble the wheel and see if you can see any movement there.
    If not then there's a good chance it's your wheel bearings.
    Pull them out and inspect them before tightening them up as they may be worn.
    Good chance to repack them too, both sides!
  3. The Following User Says Thank You to GUtsy ute For This Useful Post:
    Crowman23 (20th June 2011)
    Banned
    Maybe but not always....... You could have a crook king pin bearing in you ball hub.
    Apr 2011
    Howdy
    Thanks YNOT and all if any one else is looking to do this Job or more have a look at this link:
    http://www.nissanpatrol.com.au/forum...wheel+bearings
    I finally got that drive gear of and both lock nuts were very lose, undone both with little effort repacked with grease and toghtned to specs and 1/2 Hour later Jobs done.
    Regards
    Neil
    Expert TuffTD42's Avatar
    Feb 2011
    Central West, NSW
    After fitting 35's my drivers side wheel bearing would work its way loose over time so I fitted GU locking system. Fixed the prob.
    The conspiracy theorists were right!
  7. The Following User Says Thank You to TuffTD42 For This Useful Post:
    Crowman23 (22nd June 2011)
    Expert Russell1974's Avatar
    sometimes its good just to recheck them after a tank or two
  9. The Following User Says Thank You to Russell1974 For This Useful Post:
