Results 1 to 10 of 11
Thread: rock sliders to suit gu 6
    Expert grimace's Avatar
    Apr 2011
    central coast N.S.W
    g'day guys, i was in the market for some rock sliders for me GU2008 dx which look good and also do what they are ment to do. i would prefer that they were DIY bolt ons and that can be easily installed by myself, any suggestions would be great. also is it better to weld to the chassis?
    2008 GU 2" LIFT, GME UHF BLACK KING WHEELS, SAFARI SNORKEL, LIGHTFORCE 240' KAYMAR DUAL WHEEL CARRIER STEINBAUER POWER, beaudesert 2 3/4 system, runva 11,000 comp winch.....
    Patrol God nowoolies's Avatar
    Perth
    no dont weld to the chassie you`ll stuffit
    have a chat with Mike XLR8 hell set you right
    HELL NO !!!!!!
  3. The Following User Says Thank You to nowoolies For This Useful Post:
    grimace (17th June 2011)
    Finding bolt on sliders won't be difficult, check this link for sliders made by Superior engineering; http://www.superiorengineering.com.a...h=31_32_34_186
    Welding directly to the chassis needs to be done properly by someone who knows what they are doing or it will weaken the chassis. Bolt on is much easier and still plenty strong.
    Tony
  5. The Following User Says Thank You to YNOT For This Useful Post:
    Perth WA
    63 Post(s)
    As Nowoolies said, check out XLR8's sliders http://www.xlr8fabrications.com/Rock-Sliders.php I have got some on the Q and they are great.
  7. The Following User Says Thank You to Woof For This Useful Post:
  8. #5
    Hardcore 04OFF's Avatar
    Brisbane,QLD
    12 Post(s)
    Check with your local laws, but Welding to the chassis is a bad idea as it is normally not legal.
  9. The Following User Says Thank You to 04OFF For This Useful Post:
    grimace (18th June 2011)
  10. #6
    I looked at a load
    ARB - Overpriced for the little protection they offer
    Ironman - cheap but quality is questionable
    Bolsys - cheapest top quality and include full slider and steps - I'd go those if I was over east
    XLR8 - went with Mikes even though they are a little dearer - very reasonable install cost and right here in WA
  11. #7
    Oh - one thing I forgot - if you're installing yourself don't forget to put the chassis mounts behind brake lines, fuel lines etc. Had a mate s#rew that one up......
  12. #8
    brisbane
    weld on sliders would have to be the worst idea mate. i have repaired alot of chassis for guys after they have peeled there chassis open. def get bolt on mate. plus weld on are illegal.
  13. #9
    Patrol Guru Morton's Avatar
    Sydney West
    Quote Originally Posted by Jol View Post
    x 2 on this, you will be able to move them out of the way to slide it in place, gingerly use a long flatblade screwdriver to bend then out of the way, fit the slider, bolt it up tight then look at the lines again, makesure you have 2mm minimum clearance, stops any rubbing & potentially future failures
    2002 3L GU Patrol, 2" lift, 33's, snorkel, dual battery, sliders, DVD, bluetooth
  14. #10
    brisbane
    I’ve got tjm sliders/brush bar.... and I’m not impressed I’ve bent mine up into the sill and dented it, it’s not all that noticeable but shouldn’t happen . Look for ones with 3 mounts/support arms not 2 the more support the better. Good luck with your decision
