Results 1 to 10 of 16
Thread: Changing diff oil
    Expert 1peter's Avatar
    May 2011
    Caboolture QLD
    Changing diff oil
    Can anyone tell how to change the diff oil in my GU and what weight oil to use ? I will be using Penrite. Any help appreciated.
    Expert scotty83's Avatar
    Apr 2011
    Hillcrest, QLD
    Will need to know which one. Front and Back use different oils due to the Limited Slip Rear Diff.
    There is my list of oil weights and amounts: Mine is a 3L 2005. some things may vary slightly depending on which model you have.
    Oil - Penrite HPR 15w-50
    Front Diff (5.4L)- 90w hypoid
    Rear Diff (2.1-3L)- Penrite Limslip Hypoid 85w140
    Gear Box (3.9L)- 75w85 Gear Oil
    Transfer Case (2.2L)- 80w90 Gear Oil
    Power Steering (1L)- Dexron II
    Glow Plugs x4 - GPN-900
    Welcome others for any other info you may have here.
    ScottyB
    Scotty B | Take it Off Road or Take it Back
    3.0L GUIV 2005 - TIG Welded Intercooler, NADS, Redarc Dual Battery, Additional rear power socket, 2" Lift (Ironman constant load foam cell), Electronic Trailer Brake Controller, Steel Bullbar, 12,000lb Winch, UHF
  3. The Following 3 Users Say Thank You to scotty83 For This Useful Post:
    dhiren_motilal (8th April 2015), fixer982 (10th June 2011), frenzy (31st March 2012)
    Apr 2011
    Hillcrest, QLD
    Forgot the best bit of advice i have ever been given. remove the filler plug first. Just in case you can't get it out. oil doesn't flow uphill.
    there are some pictures around the forum from people who use Funnels and garden hoses to get the oil back in.(sorry couldn't find them) i am trying a big sauce squeeze bottle next time.
    Feb 2011
    Shed
    45 Post(s)
    Quote Originally Posted by scotty83 View Post
    Dont bother with the sauce bottle mate itll send ya over the edge. For about $20 you can pick up an oil pump like a big syringe from somewhere loke sprint auto parts or the like
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    ScottyB
    Top response mate - well done!!!
    May 2011
    Caboolture QLD
    Brilliant, I"ll be on it today after work. Ah work, don't ya love it. Thanks a bunch guys, I'll get this truck sorted out yet.
    hey mate if you can, before you are about to fill try and heat up your new oil a little, put the whole bottle into a big pot of water and heat er up on the BBQ if you have too. the oil si as thick as crap. if you have not got something to deliver the oil through (as per Plassies post or a McNaught Pump) then you will be there a Loooooong time and yor arms will be wrecked.
    That is what i use and would be lost without it. I have done it once without this pump and NEVER AGAIN!!
    ****P.S. Nice Bike
  9. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  10. #8
    Feb 2011
    Brisvegas
    some people adapt a pump up garden sprayer - I have used the mate's 20l drum pump, and a littler version for the 5l bottles.
    The manual calls for thread sealant. My advice is to be a bit thoughtful about how tight you do the bungs up. Neither I nor my mechanic could undo some of the plugs on my old MQ - the next step was applying lots of heat, but as it turned out we moved onto the GQ while pondering the next move. Maybe if I drove the Q a bit more and thus had more regular oil changes in the transmission and diffs they wouldn't have grown in, or whatever they did :-)
    Tight enough not to leak or fall out, but not tighter :-)
  11. #9
    May 2011
    Caboolture QLD
    Well the rear diff is done, that stuff is pretty thick, even with the pump. I didn't use thread sealant so we will see ? Glad i didn't have to push it throught the hose attached to the Penrite bottle, i would still be there. The vibration i had when taking off in the truck is just about gone. Thanks all.
  12. #10
    Expert Boagie's Avatar
    margaret river wa
    i would put redline oil in it if ya can afford it--it is the best by far
    You don't drive...you patrol!
    99 gu dx 4.2 diesel cab chassis - "THE GOLD DIGGER"
