Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 53
Thread: Truck lift - Your opinion is wanted!
    Feb 2011
    Shed
    45 Post(s)
    Quote Originally Posted by HippoNZ View Post
    First things first I need the clearance. At this point in time I don't realllllyyyy need the flex but will want it when I join a club. So I'd say both for the long run.
    Just like to say I have really appreciated your guys help so far, you have all brought up some bloody good points that I would have missed and probably kicked a fuss when the trol won't drive! haha
    I think I'm rather convinced on the idea of going 4"inch spring lift. But then again I said that 2months ago and my mind keeps changing! lol
    I don't just want the lift for looks but to enhance my off road ability too.
    Generally speaking I'll only have tools in the back and some fat mates lol weighing me down since being a swb and all I won't have a ton of gear.
    Keep up the 2cents worth as any opinion is accepted!
    cheers guys
    Brett
    Ok add another 2bob worth ididnt realise you're a shorty, i've got a wagon im sure when you go over 2" on a shorty you need to do somethin with tail/drive/prop shaft whichever u prefer to call em and also adjust the height of ur gear box...........research, research, research mate, hopefully ther are some shorty owners here that can advise ya
  2. #22
    22 Post(s)
    ooo and dont forget your drive shaft with a shorty and depending on the amount of flex it may separate at the slip yoke
    96 GQ coil/Cab
    08 G6eT
  3. #23
    22 Post(s)
    Quote Originally Posted by growlers71gq View Post
    doh u beat me too it
    96 GQ coil/Cab
    08 G6eT
  4. #24
    Feb 2011
    Shed
    45 Post(s)
    HAHHAHA sorry mate reflexes like a steel trap hahahahahaha
  5. #25
    Expert Forced Offroad's Avatar
    Apr 2011
    Logan/Daisy Hill
    I cant find it but there is a bloke over in NZ that got over the superior engineering complete lift...He was wrapped about, one of the first nissans to run it in NZ
    http://www.superiorengineering.com.au/
    4inch springs, drop boxes which also pushes the front diff forward 10-15mm helps with 35" shoes
    I ran that gear in comps and went well
    FORCED OFFROAD
    Built by NISSAN Powered by HOLDEN Perfected by ME "hulksta"
    http://www.youtube.com/watch?v=3GX2M...layer_embedded
    http://www.nissanpatrol.com.au/forum...Gq-v8-daul-cab.
  6. #26
    Expert HippoNZ's Avatar
    Feb 2011
    New Zealand
    Quick question, if I downsized to a 3" lift what disadvantage would that give me? And what advantage besides being cheaper would it give?
  7. #27
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    3 and 4" are both going to give you grief around the gear you need to swap out mate - you'll still need panhards, you'll still need extended link pins, extended brakes lines, caster correction, etc - could you get away with not doing some things? Probably. But at the expense later when something goes "twang" or worse!
    Why the thoughts of dropping? 4" is what I have in mine and it doesn't make it a monster truck by any means, but certainly opens up clearance under the rig.
    Good luck with the decision.
  8. #28
    Feb 2011
    New Zealand
    Quote Originally Posted by Bigrig View Post
    Cheers mate, I do see your point and since this I have seen a few rigs with only the 3" lift running on 35 tyres and it does look a bit tight for space - 4" it is but the wallet got a hiding the other day buying a new alternator so I guess that means more time to dream, atleast those are free!! haha
  9. #29
    Oct 2010
    Haha! Good luck mate whichever way you go (4"!!! Lol) ...
  10. #30
    Apr 2011
    lebanon
    i did my gq swb 5 inch lift and fitting 37 inch with some cutting behind front and rear wheels drop box and adjustable panhards and control arms
